| Kawasaki Teryx Electrical Discussions Kawasaki Teryx electrical discussions.
Lighting, audio, GPS, communications, etc. |
#1 (permalink) |
Quick question in regards to dual battery setups.
For those of you who have incorporated this into you machine, how did you do it? Did you run the batteries in series off of each other, or is there some sort of block that needs to be used? Also, where did you mount it considering the factory battery is under the drivers seat. Also, can I assume the stock alternator is not sufficient to charge both batteries, am I correct? With that said, those of you running HID's or LED lightbars, are you using dual batteries or are you running off the single factory battery?
| Sponsored Links |
#4 (permalink) |
So it appears you moved some electronics and placed the optima in the stock location?
After researching, not sure the dual batteries are going to help me...I am looking at working with a shop to develop an alternator system.
#7 (permalink) | |
Please keep us posted on this one. Very interested. Yea, I know all you mud, dirt and water folks, not concerned about any of those issue. |
#8 (permalink) |
The bigger question is once you get all your electronics installed are you gonna pull more wattage than the stock system can provide. The Teryx stock stator puts out around 338 Watts...as long as you don't load down the stock charging system with electronics you don't need a second battery. If you do, the best method is add a deep cycle second battery (optima) and run all your accessory electronics off of that battery. Use a battery isolator (sure power 1314) to insure that your not going to kill your main (ignition) battery and then just charge your accessory bat. with an external charger. The isolator will insure that if the main battery voltage output drops below 12.8Vdc, it isolates (removes accessory load) to only charge the ignition bat. and keeps it charged. If your system has enough "juice" to bring the charge in the main back up to 13.2Vdc it will parallel the batteries.
Optimas should have no issue with running HID's and steroes for hours on end before they die. Because they are deep cycle they will not be damaged from running to dead and recharging... The biggest issue with upgrading the stator is you also have to upgrade the rectifier to insure that the output is stable under load. Finding the operating RPM range for the coils and then the correct rectifier can be tricky. Do you have anyone that is working on a HO stator kit? |
#9 (permalink) |
Rickystator was looking for a Teryx to mock one up, I happened to have mine down in Ramona getting a cage built, tried to make it happen, but it didnt happen. Just got off the phone with them, still nothing.
I have their HO stators in all of my toys, love their products, hope they do they Teryx |
#10 (permalink) | |
Have you used this product on an actual Teryx? If so, which wire do you grab, color and location I should grab it from. Just ordered one online. Heard alot of good things about the sure power 1314, all good. |
| Tags |
| battery, teryx |
| Underhood Battery Tray | dieselpowered | Kawasaki Teryx Electrical Discussions | 15 | 07-30-2008 10:32 AM |
| All times are GMT -6. The time now is 09:32 AM. | |||||
