Old 09-16-2008, 09:47 AM   #1 (permalink)
Teee-rible is on a distinguished road
Default 87..91.. Gas which octane do you run?
Just curious how many people run premium gas, does it make that much of a difference?
Teee-rible is offline   Reply With Quote
Old 09-16-2008, 09:53 AM   #2 (permalink)
az_amsoil is on a distinguished road
I run reg...no problems
az_amsoil is offline   Reply With Quote
Old 09-16-2008, 11:27 AM   #3 (permalink)
Mikeomo is on a distinguished road
Default Been Wondering the Same
I know that the owners manual says it's fine to run 87, but I run 91 anyway.
I've heard that there is no performance gain by running the higher octane, and no benefit to the engine or fuel systems, but the Teryx doesn't use much gas so the price difference is minimal. Since I have never heard a definitive answer on whether or not there is any benefit to running the higher octane, I use 91 just incase there is.
Mikeomo is offline   Reply With Quote
Old 09-16-2008, 02:12 PM   #4 (permalink)
DougS is on a distinguished road
Higher octane is usually better when the timing is advanced (aftermarket CDI).
DougS is offline   Reply With Quote
Old 09-16-2008, 02:29 PM   #5 (permalink)
I have always run 91, so I really have nothing to compare.
www.RhinoTalk.net
dieselpowered is online now   Reply With Quote
Old 09-16-2008, 03:37 PM   #6 (permalink)
Well, I have the Dynatek CDI, so I guess it is better that I put 91... Do you know why it is better to put 91 with an aftermarket CDI?
Old 09-16-2008, 05:33 PM   #7 (permalink)
Hambone is on a distinguished road
There is no performance gain in running 91 octane if the engine is stock.
Hambone is offline   Reply With Quote
Old 09-16-2008, 05:55 PM   #8 (permalink)
This thread is the perfect example of why I put 91. Some say premium provides some sort of benefit (not necessarily HP) regardless of the makeup of the engine, some say it provides a benefit only under certain qualifications (such as a Teryx w/ an aftermarket CDI, or significant other mods), and some say no benefit at all... But NOBODY says there is harm done by putting 91. So, I'll play it safe and keep putting premium in the tank. I'm far from affulent, but I can afford the extra $1 per tank that it costs
Hopefully someday I will run across the black & white answer to this question!
Old 09-16-2008, 06:18 PM   #9 (permalink)
High octane gas burns slower than lower octanes.
Why do we need high octane and low octane fuel?
Octane requirements go up when compression is raised or when spark is advanced in order to reduce detonation. This is normally the case with high performance engines
When compression is lowered, the octane requirement goes down too. Your stock Teryx engine is not what would be considered a high performance engine.
In fact, you are wasting your money by using 91 octane and quite possibly reducing power output.
Lastly, the black and white answer is on pages 40 and 41 of your owner's manual.
Old 09-16-2008, 07:02 PM   #10 (permalink)
Talking
Well, the owners manual is not a black & white answer. If you listen to the owners manual on everything you will not take the Teryx out to play because it might roll over and kill you, and you won't make any performance mods to the Teryx because it might roll over and kill you, and you won't put seats in the bed and extend the roll cage because the Teryx might roll over and kill all of you... So, I don't consider the manual the black & white answer on much of anything (maintenance not withstanding). And I have read the manual cover to cover.
Thank you for your tutorial on what the differences are between the higher octane levels, and how that may affect performance, that was informative.
High Octane Motorsports Expo Custom Creations Western Region 6 03-19-2008 09:45 PM
