| Kawasaki Teryx General Discussions General discussions pertaining to the Kawasaki Teryx.
Maintenance, cleaning, etc. |
#1 (permalink) |
took my teryz to the dealer to have the carb and roof recall done.i go to pick it up and its spitting and sputtering and barely runs and they say its been doing this since i brought it to them?ive had it for 6 months with no problems.i drove it through some pretty heavy rain to get it to the dealer(so maybe it has water in it)? took the carbs off,took them totally apart,siphoned all the gas out of the tank,blew out all the lines to the fuel pump,blew out the fuel filter.
go it to run after that and seemed normal.went out and rode tonight and it screwed up again within 3 miles. now it wont even start without shooting some starting fluid or carbcleaner into the carbs,then it wont run but about 5 seconds?? im totally lost anyone have any ideas??
red le 28" bugs nukes audiopipe belt snorkels dyna HW carb kit overdrive plate xpatv lift super atv bumper Night Owl Hids k&N billet intake grant wheel |
| Sponsored Links |
#2 (permalink) |
When you pulled it off the trailer to give it to them did it run? I do not trust dealers at all.
What makes you think its bad gas? Does it have good spark? Did you check the spark plugs? wet? dry? Maybe a vacuum leak? |
#3 (permalink) |
Make sure they did not pull a spark plug wire or the other end at the coil by mistake. Also vacuum lines. They had to have the center plastic off to do the carb recall, there are other wires there that probably need to be plugged in. I am no expert at all, but since we know they had the center plastic off, start there. Also, look for oil in your airbox.
That sux, the dealer is supposed to make your Teryx run better not worse. |
#4 (permalink) |
it ran fine when i gave it to them,but i only drove it about 20 feet to park it. there was water in the gas,i drained it and put new in and there was definately a differencei in color and smell.there was oil in the carb vent lines and also gas blowing out of the rear head pipe gasket.i pulled the rear spark plug and it had some trash on it,cleaned it off and put it back in
#5 (permalink) | |
#6 (permalink) |
just dumped the tank and put new 91 in it, and blew out all lines again.changed spark plugs.i have fire on both plugs,and all wires are tight on both coils. it will sit and idle and rev up,but 1/4 throttle it still craps out.im going to go ride it and see what happens.what electrical issues could it be?
#8 (permalink) |
guess what,pos didnt run for nothing. ran around for probably 5 minutes till the first time it died.let it sit for 20 minutes then it mysterisly started.ran around for about an hour then dying again.shook the wires under the seat and it ran(almost like it was only running on one cylinder). it would run fine til i hit the rev limiter then it would crap out and die.then i would bang the stock cdi and it would run again til i hit the limiter then it would do the same thing(spitting,sputtering,and dying).then the last time it died it wouldnt start at all.i then took off the fuel pump took it apart and cleaned it out.now it acts like its not getting fuel,it wouldnt pump any fuel into the fitler let alone into the fuel pump.i ran out of starting fluid and carb cleaner so i dont know.one time jiggling the wires under the drivers seat fixes it then the next time its not getting fuel??another guy on the other forum is having the same problem as i am so im waiting to hear back from him,but its looking like mines going to the dealer monday??
#9 (permalink) |
You probably checked the fuel filter but FWIW,
I have seen fuel filters that had crap in them, when you run the engine the crap gets stuck to the filter element and starves the engine of fuel, and when you don't run the engine as hard the crap falls off the filter element and allows it to run again. Also, could be the same kind of thing inside the fuel tank on the screen that is on the pick up tube. Good luck! Be sure and tell us what turns up being wrong. |
#10 (permalink) |
ive cleaned both the fuel filter and screen on the pick up tube about 8 times?
| Muzzy's Exhaust Install problems - Does yours fit your Teryx? | Magellan | Kawasaki Teryx Performance Discussions | 28 | 09-19-2008 06:25 PM |
| New Teryx problems!! HELP!!! | pikester | Kawasaki Teryx General Discussions | 15 | 09-17-2008 04:50 PM |
| New and already have problems | Lhall | Member Introductions | 7 | 08-25-2008 09:39 AM |
| teryx problems | PWADE | Kawasaki Teryx General Discussions | 1 | 06-04-2008 09:23 AM |
| Teryx Problems | PWADE | Member Introductions | 10 | 06-03-2008 04:16 PM |
| All times are GMT -6. The time now is 09:58 PM. | |||||
