Old 10-10-2008, 12:50 AM   #1 (permalink)
bradenbaugh is on a distinguished road
Default 4wd help??!!
for some reason my teryx is stuck in 4wd even though i have the switch in 2wd!! i had this problem before and after driving it for a long while (15 mins) it finally changed back to 2wd. thats not the case now. i have put new fuild in the diff (motor oil!!??) no water in the old though. is there a relay could be bad?? switch maybe??? anyone else have this prob???
bradenbaugh is offline   Reply With Quote
Old 10-10-2008, 01:49 AM   #2 (permalink)
Do you have an aftermarket CDI installed?
www.RhinoTalk.net
dieselpowered is online now   Reply With Quote
Old 10-10-2008, 01:51 AM   #3 (permalink)
yeah a Dynatek non programmable
Old 10-10-2008, 01:53 AM   #4 (permalink)
Well a while back, the VDI had an issue with the 4x4.
Let me ask you this, did you put it in 4x4, drive around and then just throw it in 2x4? If this happens again, stop, put it in reverse, go back really quick, then put it in drive and see if it disengages.
www.RhinoTalk.net
Old 10-10-2008, 01:56 AM   #5 (permalink)
yeah tried all that forward reverse stop and switch it switch it while moving got mad hit the switch to hard dont do that pain in the a** to get it out the dash without pullin it appart switch feels like it is workin though
Old 10-10-2008, 02:00 AM   #6 (permalink)
Hmmm I am not sure...the only problems with 4x4 that I know of were due to the VDI, but those were taken care of. Are you still under warranty?
www.RhinoTalk.net
Old 10-10-2008, 02:06 AM   #7 (permalink)
they wouldnt wanna touch mine lifted, snorkled, jet kit, cdi, pipe, 29.5 laws. dealer would turn me around before i unloaded it. i was a yamaha man before i got the teryx i know yamaha 4wd set up in the diff. how does the kawi diff kick in and out of 4wd?? whats crazy is when it did this before it finally kicked out after drivin a while. i have a buddy with a 650 he has the same prob. lucky they both stuck in 4wd.
Old 10-10-2008, 06:23 AM   #8 (permalink)
There is a actuator on drive shaft side of the front diff and it slides a collar back and forth in the input shaft.
With engine off, can you hear it with the key on and flipping the switch?
Old 10-10-2008, 06:43 AM   #9 (permalink)
no cant hear it.... i was thinking something electrical because the 4wd on the display is on(even with the switch in 2wd) and what i have read up when the actuactor screws up alot of people were saying there display was switching back and forth from 4wd to 2wd. i do alot of mud/water riding so i was thinking maybe relay??? but i dunno if one the ones under the seat is even for the 4wd?? oh and i have already unpluged em cleaned the conections and greased em
Old 10-11-2008, 10:03 AM   #10 (permalink)
vent line is clear..... ok when i put it in 2wd the cable lets out but does not move but a hair.... could that actuator in the diff be stuck??? if so how do i take it apart to clean it????
