Rear Diff Fluid - Kawasaki Teryx Forums: Kawasaki UTV Teryx Forum
post #1 of 13 (permalink) Old 12-31-2008, 12:30 PM Thread Starter
ZackTeryx's Avatar
Rear Diff Fluid
Do you guys know of any large chain stores that will carry the fluid for the rear diff's? I have tried hunting around locally and have came up with nothing. I did go to Chaparral Motorsports (local parts supplier) and they recommended i use Kawasaki Gear Oil P/N 19-1303. Its a Hypoid oil recommended for the Mule. I havn't put it in because i figured that if Kawi wanted that oil to be used... They would have put it in thier service manual.
Locally i can find tons of different Hydraulic fluid, but no one has the brands/models listed in the service manual.
Please help!!!
ZackTeryx is offline
post #2 of 13 (permalink) Old 12-31-2008, 05:03 PM
glamisrob's Avatar
I have heard good things about Amsoil. Check with message board user AZ Amsoil. He can hook you up with what you need.
glamisrob is offline
post #3 of 13 (permalink) Old 01-02-2009, 08:27 AM
Thanks Rob...
Please help!!!
I have the oil you need for the rear diff, DON'T USE GEAR OIL!!! You need a hydraulic/tractor fliud for the rear brake. Kawai doesn't make it, that's why they spec the mobil stuff in the data sheets. The AMSOIL ATH meets this spec. I sent you a PM.
post #4 of 13 (permalink) Old 10-27-2009, 12:50 PM
rear diff oil
I found the Mobilfluid 424 at Grainger on line. Pricey at $46.00 for 2.5 gals plus ship, should be a lifetime supply.
Randy
meflyfish is offline
post #5 of 13 (permalink) Old 10-30-2009, 11:14 PM
jeryx's Avatar
I found this thread
Just thought i would add this for those who are having trouble finding the proper fluid for the rear diff.
NAPA part # 85-401
it meets all the criteria and it comes in 1 gallon jug, for about 12 bucks!
I figure i should be able to get 3-4 changes per jug.
Wheres that big rock now!
jeryx is offline
post #6 of 13 (permalink) Old 07-05-2011, 04:17 PM
Amsoil Larry's Avatar
Hunterworks Sells Amsoil!!!
Hunterworks sells Amsoil synthetic lubes at factory direct pricing! Call Larry at 866-580-1008
And yes....you have to use a lube with the correct friction modifiers for the wet brake...Amsoil ATH is the answer!
Amsoil North American Wholesale
www.sowoil.com
866-580-1008
Amsoil Larry is offline
post #7 of 13 (permalink) Old 07-06-2011, 01:02 PM
Nozzleweed's Avatar
diff oil
Well HOLY #$%*. I just changed my diff fluids both front and rear. It was recommended by the dealer. Used the same Synthetic stuff for both. Now I read here that there is different stuff for front and back. WTF.Someone clear this one up for me please.
"infected by the MAD KAW " Mudforce"
2010 Teryx
30 Mudzillas
Muzzy
Warn winch
Uni with Billet adapter
Dalton clutch kit
3" Gorilla lift
Mud Industries Snorkle with Armor tips
Nozzleweed is offline
post #8 of 13 (permalink) Old 07-06-2011, 01:26 PM
nyteryx's Avatar
I have changed my diff fluids both front and rear to royal purple gear oil. Just make shure what you use doesent have friction moddifiers as it can damage the front locker clutch pack and rear brake pack. I have around 1600 miles on my royal purple diff oil and all is well. 2300 miles in the machine and original brakes and front locker clutches and no seals leaking. Some guys are using hydralic fluid and im shure there are other fluids being used. Im not shure of the rating as im at work but someone with a manual should tell you what the required rating is. My Suzuki king quad had the same rear brake set up in it and it had 4000 miles on royal purple gear oil in the rear diff when i sold it and had the original rear brakes. Good luck.
nyteryx is offline
post #9 of 13 (permalink) Old 07-06-2011, 01:36 PM
The same motor oil you use in the engine is fine for the front diff....the rear diff requires a oil compatible with a wet brake. I recommend Amsoil's full synthetic tractor transmission fluid. It protects like a gearlube...pumps like a hydraulic fluid and works really super with the rear diff's wet brake.....
www.sowoil.com
866-580-1008
post #10 of 13 (permalink) Old 11-03-2011, 05:13 AM
I know this is an old thread but I was having trouble finding the fluid in Barrie Ontario and found a suzuki gear oil for wet brake sytems, is this the same?
trafficticket is offline
Human Verification
In order to verify that you are a human and not a spam bot, please enter the answer into the following box below based on the instructions contained in the graphic.
20 hour fluid change; not bad at all..... nobodysguess Kawasaki Teryx General Discussions 26 05-03-2013 06:30 PM
another diff seal puddle jumper Kawasaki Teryx Performance Discussions 33 06-07-2010 05:04 PM
billet shifter and diff. lock dad n buggy Kawasaki Teryx Exterior Discussions 1 12-10-2008 08:22 PM
Front Diff Oil kennyo15 Kawasaki Teryx General Discussions 4 10-20-2008 06:44 PM
Teryx Diff Button Assy John@UTVCRAP Kawasaki Teryx Exterior Discussions 2 05-14-2008 09:03 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67
