09 rex 51 mph??? - Page 2 - Kawasaki Teryx Forums: Kawasaki UTV Teryx Forum
Home Media Gallery Register Garage FAQ Members List Search Today's Posts Mark Forums Read Advertise
09 rex 51 mph???
This is a discussion on 09 rex 51 mph??? within the Kawasaki Teryx General Discussions forums, part of the The Garage category; How does it compare to the PC5? The PC5 can tune each cylinder, has an auto tune add on available,
Kawasaki Teryx Forums: Kawasaki UTV Teryx Forum > The Garage > Kawasaki Teryx General Discussions > 09 rex 51 mph???
Old 05-26-2009, 03:55 PM   #11 (permalink)
DASARACING is on a distinguished road
How does it compare to the PC5? The PC5 can tune each cylinder, has an auto tune add on available, fuel can be added every 250RPM. I know the PC5 retails for $359.99 but you will still need another plug in ignition to get around the speed limiter and TERRIBEL STOCK IGNITION CURVE.
DASARACING is offline   Reply With Quote
Old 05-26-2009, 04:23 PM   #12 (permalink)
DRAGONFIRERACING's Avatar
DRAGONFIRERACING is on a distinguished road
I have yet to look into the PC5. With our ECU and throttle body set-up it will come with a CD that has pre programmed maps you can download. You also have the ability to write your own maps, with this set-up you can change air, fuel, RPM, and timing. This is not a fuel controller its best described as a motor controller giving you precise tuning no matter the application.
DRAGONFIRERACING is offline   Reply With Quote
Old 05-29-2009, 06:39 AM   #13 (permalink)
Areed is on a distinguished road
Here are somethings that you can change with this system
-Fuel Enrichment during cold starts
-Elevation changes
-Dwell for coils, not exactly sure if that's the correct term, similar to MSD multiple spark discharge
-Fuel to each cylinder
-Autocorrect up to 120 times a second
-Pull timing out in boost
- have to different tunes on tap at the flip of a switch.
There's a lot more but this is highly advanced.
09 Teryx - FST 840, DFR Intake, DFR Dual Exhaust, DFR Throttle Bodies, DFR Standalone, Dalton Clutch, 26" Bighorns, Stock arms w/ Fox DSC RD, Power Steering, PRP Comp Pro Seats, 4130 Chromoly Roll Cage, Angry Neighbors
Areed is offline   Reply With Quote
Old 05-29-2009, 06:45 AM   #14 (permalink)
I'm that guy, I still think I'm the only guy with it too, the computer system is unreal. For you car guys, this makes Megasquirt systems look like junk, think of it as a advanced AEM standalone for a SxS, except much better with much more options. If I want to turbo later its just as easy as building new maps and changing the map sensor in the computer to handle the boost. The coils that come with it make MSD look like crap. Bud at Redline says they will support a formula 1 car up to 19,200rpm. Now I know a Teryx has no business much over 10k but I'm trying to express the quality of everything that you get for 2k. Changing the amount of fuel to each cylinder is important since they like to run lean on 1 cylinder. When Bud tuned the car it was like a training session with huge results, if you can tune a car, you can tune this. Ill take some pictures of the screen and let you see everything involved, its amazing. Oh, and having 100hp ain't bad either!
As far as the top end I'm not sure. I need to shed some pounds of the car still. Without a machined clutch I should see 75-78 maybe. Dragonfire is hitting 90 in the desert.
Originally Posted by DRAGONFIRERACING View Post
It is way more than just a computer though you can change almost every aspect of the motor with this system and it gives you all the room in the world to grow. Cool story we actually had a guy in North Carolina that was having issues setting his up, he called Todd who was in California and Todd tuned his car in North Carolina using the wi-fi capability of the system. It is truly leaps and bounds ahead of its time. With our 840 kit we are looking at 100HP at the motor.
Old 05-29-2009, 08:10 AM   #15 (permalink)
Our setup will be about $700.00 ...... for the programable fuel controller and the programable ignition. All this stuff will bolt right onto your stock 2009 teryx. Both will support any engine mods you do. We should have a top speed reading on a stock 2009 this weekend. Then this same system will be used on the 840 build next weekend. This system is affordable and will do everything you need and more ....... You can split maps and tune each cylinder individually. We will be setting the rev limiter at 9k as tha tis what we think the stock valve train will support, but we can set the rev limiter at whatever you want or completely remove the rev limiter.
Old 05-29-2009, 08:57 AM   #16 (permalink)
powertrippin is on a distinguished road
hey thanks so much for the info...just wasnt sure why so much chadda$$ my computer for my Ls1 powered sand rail was right at 1K..and is fully programable...sound like this rex is gonna haul azz......
here lizard lizard...
powertrippin is offline   Reply With Quote
Old 05-29-2009, 12:46 PM   #17 (permalink)
Boot Hill Express's Avatar
Boot Hill Express is on a distinguished road
mine will do 51 mph with current mods, I unplugged the speed sensor on the tail of the transmission and rode next to rzr-s down a few long roads at about 63 mph. still waiting for the do-it-all box for fuel and limiter fix. can't ride the trail with speed sensor unplugged because the belt safety gremlin slows it down, only helps foot on the floor top end, and probably runs a little lean at higher rpm.
09 teryx blue, self made diamond plate alluminum top, muzzy exh., mamoth i pod speekers, 27" bighorns on itp 212 wheels, bed rails,fender flares, hurst shifter, dalton clutch kit and overdrive cover.
Boot Hill Express is offline   Reply With Quote
Old 06-01-2009, 07:54 AM   #18 (permalink)
Found a plug and play unit that overides the speed sensor ..It can be recalibrated to run several ratios...spose to pull an extra 5 to 6 miles an hour outta the rex...just sayin...it was like $$109.00...whatcha guys think
Old 06-01-2009, 08:11 AM   #19 (permalink)
That is what our speed box does but the way we wire it, it does not interfere with speedo.
www.hunterworks.com
Old 06-01-2009, 08:38 AM   #20 (permalink)
can you explain a little more.....thx
Disco'd the REX! dave_dj1 Kawasaki Teryx Suspension Discussions 19 07-07-2009 05:48 AM
DFR's Cheap way to get extra 5+mph DRAGONFIRERACING Kawasaki Teryx Performance Discussions 0 03-27-2009 11:33 AM
Parts diagrams for T-rex from Kawasaki Teee-rible Kawasaki Teryx General Discussions 5 08-24-2008 03:08 PM
69 mph teryx!! puddle jumper Kawasaki Teryx Performance Discussions 4 07-10-2008 01:36 AM
Is it T - Rex? olddirtrider Kawasaki Teryx General Discussions 7 06-05-2008 04:34 PM
Powered by vBulletin® Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Garage Plus vBulletin Plugins by Drive Thru Online, Inc.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76
