Fuel Injection Conversion - Page 2 - Kawasaki Teryx Forums: Kawasaki UTV Teryx Forum
Home Media Gallery Register Garage FAQ Members List Search Today's Posts Mark Forums Read Motorcycle Escrow Advertise
This is a discussion on Fuel Injection Conversion within the Kawasaki Teryx General Discussions forums, part of the The Garage category; Originally Posted by sandwarrior The fuel pump and tank are differant, fuel injection is 43 psi and carbs are low
Kawasaki Teryx Forums: Kawasaki UTV Teryx Forum > The Garage > Kawasaki Teryx General Discussions > Fuel Injection Conversion
Old 09-22-2010, 05:36 AM   #11 (permalink)
Originally Posted by sandwarrior View Post
The fuel pump and tank are differant, fuel injection is 43 psi and carbs are low presure.You could run an external pump and regulator. What Im not clear on yet is if the crank sensor will fire the FI. it should. Ive converted a 83 toyota 22r to 22re and it used the same distributor, just had to blend in the FI harness with the factory harness. it works fine. The Teryx should be the same. All it should need is a number 1 referance (crank sensor) and the FI computer should do the rest. I have all the parts to play with, just havent had time. It will be a fun project.
Not true. The EFI needs more resolution so the flywheel has more triggers on it and the ECU counts them and fires say on trigger six and eight where as the carb version is a wasted spark and only has either one or two triggers on the flywheel
www.hunterworks.com
Old 09-22-2010, 12:20 PM   #12 (permalink)
bigdaddy is on a distinguished road
I know by talking to MDS and v force john the 2008 and the 2009 fires different, the 2009 has more pulses per rev and it is fewer tach set ups that work for the 09, I had to buy a pick up from MSD and autometer only has 2 series tachs that will work on the 2009, I was just going to go to Orilley and buy a tach but found out that is was not that simple, the 2008 was simple it had a extra wire of the ignition for the tach, I think I would be like the other guys have said buy a FI Teryx swap out all of your mods that will swap and then sell the 2008, that would be much cheaper than trying to convert most everything would swap unless it had something to do with the items we are talking about and some front bumpers want swap, if you shopped for a good deal you might could make the swap for very little difference.
bigdaddy is offline   Reply With Quote
Old 09-22-2010, 04:17 PM   #13 (permalink)
the_owl is on a distinguished road
Carb'd motors are generally cheaper to build power on too.
Pretty sure thats the case with Teryx's too.
the_owl is offline   Reply With Quote
Old 09-22-2010, 05:51 PM   #14 (permalink)
Not really, but I guess a larger set of injectors at $165 to a jet kit of $80 would be about the only difference really
www.hunterworks.com
Old 09-22-2010, 06:20 PM   #15 (permalink)
throttle bodies vs carbs?
Old 09-22-2010, 08:35 PM   #16 (permalink)
kayjay_2002 is on a distinguished road
Default fuel injection conversion
I put fuel injection on my 08 model. It starts easier and for sure has more power. I went from 34mm carbs to 40mm throttle bodies. I figure it would prolly cost about 1500.00 to buy the stuff. You need fuel pressure gauge, high pressure pump, and then you have to add a drain back to your tank. Here are some pics.
Fuel Injection Conversion-getattachment-1-.jpg   Fuel Injection Conversion-getattachment-2-.jpg
kayjay_2002 is offline   Reply With Quote
Old 09-23-2010, 05:46 AM   #17 (permalink)
So far the EFI engines have built more power at our shop
www.hunterworks.com
Old 09-23-2010, 06:17 AM   #18 (permalink)
nnadenoff is on a distinguished road
kayjay
Did you buy all new components to convert to FI. I have everything off a FI Brute Force do you think it will work since you have went throught it already? I know I will have to change the electrical harness and few others things, just unsure if it is worth it. I think it will be a good winter project.
nnadenoff is offline   Reply With Quote
Old 09-23-2010, 08:36 PM   #19 (permalink)
Default efi conversion
Just to mention, the only reason I tackled the efi was because I have a turbo ready to put back on it. What I had to buy was 2 throttle bodies w/ injectors, wiring harness, computer, tps sensor, fuel pump/gauge/fittings. You can basicly build your own harness with about 9 wires. The only thing about the stuff that I am using is its a dos based program to map it. At first I thought it wasnt worth it, but in the long run it seems to be better. I wasnt to knowledgeable about efi and it really taught me alot. I would say that anybody that wants to tackle it should go for it. I could always put the carbs back on because I didnt touch the stock wiring harnes at all.
2008 Teryx Fuel Injection Conversion dieselpowered Kawasaki Teryx Performance Discussions 20 07-29-2010 05:31 AM
Fuel injection warning light- 09 Sport tlcteryx Kawasaki Teryx Electrical Discussions 0 11-12-2009 06:32 PM
Utv Crap- Oem vs Hid conversion kit UTV CRAP UTV Crap 0 03-16-2009 11:19 AM
Muzzys Digi-Tune Fuel Injection Controller dieselpowered Kawasaki Teryx Performance Discussions 7 12-21-2008 06:51 AM
Fuel Injection PetesZ400 Kawasaki Teryx General Discussions 19 05-26-2008 02:49 PM
Powered by vBulletin® Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Garage Plus vBulletin Plugins by Drive Thru Online, Inc.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62
