| Kawasaki Teryx Performance Discussions Kawasaki Teryx performance discussions.
Engine mods, CDI boxes, exhausts, etc. |
#11 (permalink) |
The stock Teryx has a second timing curve in it that only allows 10 degrees of advance before 5mph and that is why the Rhino is getting you out of the hole. As said a CDi swap will change everything.
By the way, who keeps one stock anyway!!! |
#12 (permalink) |
Hey man can you post up a pic of your teryx other than your avatar? Seems like I have seen that one somewhere else,love looking at the teryx's.. Yea man just get ya a CDi and its a night/day differance.
2009 Browning 850 XP Camo Teryx LE (SOLD) *Hunterworks stereo bar and amp 4 sale* Pics http://community.webshots.com/user/hdsilverado |
#13 (permalink) | |
I'm like everyone else. If I spend the money I want the fastest one. (as long as it is reliable). And Rutcutter, I'll try and post another pic of my Teryx. |
#14 (permalink) | |
What tire pressure are you running in your Horns Rutcutter? I just got a set and I am down to 15 and they still seem to hard.... |
#15 (permalink) |
The two other things to consider is the adjustment on your clutch. If it is too far out in the adjustment range it will actually make your low gear ratio higher (not engaging until the ramps come together) In effect it will be like starting off in a taller gear. The other thing is with wider tires then the Rhino stock ones you need more power to just pull your tires.
Buy the CDI and make it a habit to check your belt once in awhile. Just because your unit might be new doesn't mean your clutch couldn't be adjusted better.
Amateurs practice to do it right, Professionals practice until its Perfect! |
#16 (permalink) | |
#17 (permalink) |
Just saw a cdi on ebay for 169
eBay Motors: Kawasaki Teryx Dynatek CDI Box (item 140273223538 end time Oct-12-08 22:40:06 PDT) |
#20 (permalink) | |
| Black Rhino | RomDOGG | Kawasaki Teryx Electrical Discussions | 2 | 07-28-2008 07:15 AM |
| Rhino Convert!!! | mikec570 | Member Introductions | 2 | 07-20-2008 06:31 PM |
| [Build-Up Sponsor] Black Rhino Performance | dieselpowered | TeryxHQ.com Announcements | 0 | 05-14-2008 01:54 AM |
| Rhino with 49s | mouser58 | Other UTV Discussions | 3 | 04-14-2008 12:03 AM |
| Rhino Mayhem | dieselpowered | Off-Topic Discussions | 4 | 03-19-2008 01:10 AM |
| All times are GMT -6. The time now is 07:10 PM. | |||||
