2009 Teryx PC5's instock - Kawasaki Teryx Forums: Kawasaki UTV Teryx Forum
Dasa Racing DASA Racing
www.dasaracing.com
951-681-1131
post #1 of 26 (permalink) Old 07-04-2009, 02:37 PM Thread Starter
This is the PC5 for the Teryx. The Dynojet Power Commander V plugs inline with your bike's stock fuel injection system. It uses OEM (original equipment manufacturer) style connectors making installation easy and quick. The Power Commander USB allows a full range of fuel adjustment, as much as +/- 100% over stock. Adjustments can be made either with a Windows based computer or by using the face plate mounted button adjusters. No permanent changes are made to the bike's system. Once the unit is removed the bike reverts to its stock settings ..... OR ...... purchase the Auto Tune kit and let it do all the work for you. The auto tune kit sends information to the Power Commander V and automatically corrects a/f while you ride. This will eliminate the need to have someone else tune your teryx. Each map that we offer has preset Air/Fuel ratio values included that we find to be the best overall settings. This lets you simply plug in and ride.
Below you will find some Power Commander V features.
Reduced size from PCIII (less than half of the size of PCIII)
USB powered from computer (9 volt adapter is no longer needed for programming like on PCIII)
2 position map switching function built in (map switch not included)
With gear position input connected the PCV is capable of allowing each cylinder to be mapped individually and for each gear (for example: on a 4 cylinder bike with a six speed transmission there could be up to 24 separate fuel tables).
Unit has a -100/+250% fuel change range (up from -100/+100%). This allows more adjustment range for 8 injector sportbikes
10 throttle position columns (up from 9 on PCIIIusb)
Enhanced "accel pump" utility (increased adjustment and sensitivity ranges)
post #2 of 26 (permalink) Old 07-04-2009, 03:49 PM
What is the expected date this will do ignition?
Do you have to install 2 oxygen sensors in the front and rear headpipes to make autotune work? How is it installed?
Thank you in advance for the info. I am definitely interested, but I want the whole package for my $$ which as everybody knows is in shorter supply this year.
post #3 of 26 (permalink) Old 07-04-2009, 04:42 PM Thread Starter
We have an ignition and fuel controller combo now ....... the only difference is it will not auto tune. If you go with the PC5 you will still need an ignition and the dynatek ignition is do out next month. That will be a good combo ..... PC5 bolt on plug in fuel controller with auto tune and dynatek ignition.
Do you have to install 2 oxygen sensors in the front and rear headpipes to make autotune work? ?
You will install the o2 sensor in one head pipe at a time. It will start making the map as soon as you drive. It will then tune both cylinders to that spec. Then you can use the split map feature and tune each cylinder individually. This thing will do alot of things and is very easy to use.
How is it installed??
all plugs right into your factory wiring.
I understand ...... we have been testing these options for about 2 months now. We have two ways to go depending on what you need and want.
#1. IF YOU HAVE ACCESS TO A DYNO OR CAN TUNE THE FUEL INJECTION
then go with our custom PC3 and programmable ignition. it will get rid of the speed limiter and rev limiter now. It will add plenty of fuel and ignition. this is what we are using on our 2009 840 build and it has plenty of room for more mods.
#2. IF YOU HAVE TO HAVE THE AUTO TUNE
then go with the PC5 then in about 30 days you will use the dynatek ignition to get rid of the speed limiter and rev limiter
Here is the BIG thing. The PC3 and PC5 will allow YOU or the TUNNER to create the PERFECT fuel curve. It is SUPER adjustable. Having the correct fuel curve will get you the most HP out of the mods you have. BOTH OF THESE CONTROLLERS HAVE THE ABILITY TO SPLIT MAPS AND CREAT MAPS FOR EACH CYLINDER .....THIS IS VERY IMPORTANT.
If anyone has any questions just let me know. These things are VERY easy to use and are the industry standard for ATV's and Street bikes. Dynojet power comanders are the BEST IN THE INDUSTY.
post #4 of 26 (permalink) Old 07-30-2009, 01:12 AM
ok question, why, i have what u and muzzy claim is a tru equal length exhaust, do i need to tune each cylinder differently, what else is an issue that makes front to back un even. or is tunin stated for the mear fact that someone might not actually buy a true equal length exhaust to equal out the cylinders. thanx
fitzazpb is offline
post #5 of 26 (permalink) Old 07-30-2009, 01:13 AM
sorry that should of said ' if i have"
fitzazpb is offline
post #6 of 26 (permalink) Old 07-30-2009, 05:09 AM
Typically you want the rear cyl running slightly richer to aid in cooling since it does not receive the air around the cyl the front does.
It has nothing to do with exhaust. They come that way from the factory too.
post #7 of 26 (permalink) Old 07-30-2009, 09:31 AM Thread Starter
The real reason you will .... WANT .... to tune each cylinder different is because the pipes are different front to rear on a stock car. There are HP gains to be made it you do tune each cylinder correctly. First you must have a controller like the PC5 that can tune each cylinder. I have not measured the stock pipes, but the rear pipe has to be about 2 feet shorter then the rear pipe.
Really it does have alot ot do with the exhaust ..... as because the stock pipes are so different from the factory.Once you go to a equal length pipe the tunes on each cylinder will be VERY CLOSE to each other, but still different to make PEAK HP.
post #8 of 26 (permalink) Old 07-30-2009, 11:40 PM
gotcha didnt know cams were different wierd, thanx for info, i'm changing cams for sure now
fitzazpb is offline
post #9 of 26 (permalink) Old 07-31-2009, 06:00 AM
The cams are not different except for what direction they go in.
If you ever heard of Mike Penland who has won 11 GNCC championships and 5 Baja Races most on a Kawi and used to race for Four Stroke knows about as much as anyone on these engines is who explained the richer in rear for cooling to me.
I thought it had to do with exhaust too, he laughed at me.
post #10 of 26 (permalink) Old 07-31-2009, 09:07 AM Thread Starter
You are correct ......Sorry what i typed did not make much sense now that i read it again. The cams duration and life are the same stock from front to rear, they did not do anything to compensate for the DRAMATIC DIFFERENCE in the STOCK pipe lengths.
Well on a quad i can see this to an extent, but on the teryx i dont see it as much. I would say the rear stock pipe is about 2 feet shorter then the stock front pipe ........ shorter pipe ...... bigger jet. Just the way i see it. Anytime you change pipe length that much you will have to rejet. Hey what he says could be true to. Either way or a combination of both .... YOU WILL WANT A FUEL CONTROLLER THAT CAN TUNE EACH CYLINDER.
F/I Auto tune is here and INSTOCK DASARACING Kawasaki Teryx Performance Discussions 1 05-09-2009 11:31 PM
