Couple of gauge questions - Kawasaki Teryx Forums: Kawasaki UTV Teryx Forum
Kawasaki Teryx Electrical Discussions Kawasaki Teryx electrical discussions.
Lighting, audio, GPS, communications, etc.
post #1 of 14 (permalink) Old 11-22-2008, 06:23 PM Thread Starter
Just curious on those who have installed the fuel gauges, what kind of sealant did you use on the gas tank that is impervious to gas and will stick to the polypropelyne type material of the gas tank? Also going to be adding a voltmeter with my second accessory battery, did you wire the gauge so it only reads when 12v switched power is on and how did you do it? Im assuming to the ignition switch or something similar. Thanks
ultimate1 is offline
post #2 of 14 (permalink) Old 11-22-2008, 09:32 PM
i am looking to add a fuel gauge also, what did you go with ( i am researching looking for options)?
post #3 of 14 (permalink) Old 11-23-2008, 01:14 AM Thread Starter
i bought an auto meter ultra lite fuel gauge, and ordered a fuel sender from gaffrig performance. It is the same sender that trail armor and blackrhino use, but i got my stuff myself, and it was cheaper. I am putting it in the space where the cupholders would go on a custom made panel. It will hold my fuel and volt gauges and all of the aux light switches and horn button. Thanks for asking. Anyone, on the sealant yet???????????
post #4 of 14 (permalink) Old 11-23-2008, 10:19 AM
Grandpa's Avatar
fuel guage and sender
I order a fuel guage, sender and volt meter from Hardin Marine. the total was around $ 135. I installed the sender without any epoxy and without removing the gas tank. First have your shop Vac close and use a drill saw , be sure not to let any of the shaving fall in the tank. The sender comes with a cork guasket , I used five stanless steel screws and it sealed quit well. Since I have a two battery system using a 1314 isolator , I connected the volt meter to the primary battery and when its charged it switched to both batterys you will see the charge on you secondary battery. One more thing be sure to sipon your gas tank befor installing the sender, you need to do this to calibrate the meter.
Grandpa is offline
post #5 of 14 (permalink) Old 11-23-2008, 12:59 PM
perks offroad's Avatar
fuel guage
I have a few fuel guages available that match very well with the teryx, also much cheaper than the catalogs. I will post a picture Monday. Azamsoil has a thread about the fuel sending unit (it will work with the guages that I have) and he has great pictures to show how its done. He also has a great oil change kit!
perks offroad is offline
post #6 of 14 (permalink) Old 11-23-2008, 03:48 PM Thread Starter
Thanks, grandpa. I also found more on this when i did a search. BTW i like how your rex matches your advantage boat. We are kind of painting ours to mach our shockwave boat as well.
post #7 of 14 (permalink) Old 11-23-2008, 05:52 PM
SXSCustoms's Avatar
The sender has a cork gasket and you will not need any sealant.
SXSCustoms is offline
post #8 of 14 (permalink) Old 11-24-2008, 02:09 PM Thread Starter
Hey sxs customs, what is that that you are using for a choke knob? I havent seen that before. Your panel that you made is very similar to what i am making, i guess great minds think alike.
post #9 of 14 (permalink) Old 11-24-2008, 03:03 PM
SXSCustoms's Avatar
Thanks ...
Its just a nice billet piece that also includes the knob for the headlights, we should have a few in the shop laying around.
post #10 of 14 (permalink) Old 11-24-2008, 04:13 PM
No need, fill a 2 liter bottle with fuel and use that to cal the sender before you install. Dunk the sender in, cal for full, pull it out, cal for empty. Then install into you fuel tank. It will get you real close. Here is the pic of the sender in the fuel tank:
Drive-belt questions kawidriver Kawasaki Teryx General Discussions 7 06-04-2009 08:35 PM
Jetting questions pikester Kawasaki Teryx Performance Discussions 6 10-19-2008 05:21 PM
New Teryx Owner with concerns/questions WildRose Member Introductions 3 08-11-2008 12:30 AM
Gas Gauge ram04 Kawasaki Teryx General Discussions 33 07-28-2008 06:58 PM
Couple Dynatek eBay Auctions dieselpowered Kawasaki Teryx Performance Discussions 5 05-02-2008 09:38 PM
