How do you wire an amp - Kawasaki Teryx Forums: Kawasaki UTV Teryx Forum
Kawasaki Teryx Electrical Discussions Kawasaki Teryx electrical discussions.
Lighting, audio, GPS, communications, etc.
post #1 of 9 (permalink) Old 01-16-2009, 09:14 PM Thread Starter
Whats up people, I'm new here and this is my first post.
I was wondering how you guys wire a amp on to a teryx?, btw I have a 2009 teryx LE silver in color.
I have an old 100 watt pioneer amp, and a xm radio that I want to hook up but I don't know where the blue wire goes, the one that turns on your amp when you turn on your stereo. I think its called remote wire.
Thanks for everyone who helps.
slick999 is offline
post #2 of 9 (permalink) Old 01-17-2009, 01:24 AM
jerwool08's Avatar
first are you going to run a battery that wont let you drain it all the way or just use a normal battery. I personaly will be running a preformance type battery that will let me drain it so I will only wire it to the on side of the key that way I'm less likley to play the radio w/o starting the motor
jerwool08 is offline
post #3 of 9 (permalink) Old 01-17-2009, 01:32 AM
I have my remote wire on a switch in my dash from the battery to power up my amp. I actually put a distribution block behind my dash for all my swiches to everything i added
jeepinbeav is offline
post #4 of 9 (permalink) Old 01-17-2009, 12:42 PM Thread Starter
I'm going to use the stock battery, its only a 100 watt amp.
I want the amp to turn on when I turn on the teryx.
So where does the blue wire(remote)go to?
Adding a xm not a stereo
slick999 is offline
post #5 of 9 (permalink) Old 01-17-2009, 05:14 PM
Slick,
"Only a 100 watt amp" It will run your battery down quickly.
Is that a two channel amp or four. Are you using all four if it is a four channel. Why is this important?
If it is a four channel amp then you will only use 50 watts which will be fine. If it is a two channel then you will be using 100 watts which will run your battery down pretty quickly.
On the blue wire, find a wire that is hot when the key is on and tap into it. Try the 12v plug, I bet it is a keyed hot. I have not checked it myself.
post #6 of 9 (permalink) Old 01-17-2009, 05:59 PM
yes the 12v plug is keyed hot used it for my winch and acc. lights
dad n buggy is offline
post #7 of 9 (permalink) Old 01-18-2009, 02:59 AM
i use to use my 12volt for the horn the rest are off my disrtribution block best thong i could added for all my extras
post #8 of 9 (permalink) Old 01-20-2009, 01:47 AM Thread Starter
Its only a 2 channel amp.
I found a way to hook up the remote blue wire.
thanks for all your help.
slick999 is offline
post #9 of 9 (permalink) Old 01-20-2009, 06:01 AM
The louder you play it the more amperage it uses. Be careful!!
08 Headlight wire diagram help crnacnac Kawasaki Teryx Electrical Discussions 8 11-22-2008 01:09 AM
