Another cooling fan issue - Kawasaki Teryx Forums: Kawasaki UTV Teryx Forum
Kawasaki Teryx Electrical Discussions Kawasaki Teryx electrical discussions.
Lighting, audio, GPS, communications, etc.
post #1 of 10 (permalink) Old 08-18-2010, 11:53 AM Thread Starter
Question Another cooling fan issue
I have a similar problem with my 08 Teryx cooling fan. It keeps running until I disconnect the batt and wait a few minutes, reconnect the battery and it is fine till my next ride. Is the problem with the fan sw (27010-0091) or the sw sensor water (27010-1346) that is the culprit. Is there a way to test which is causing the problem. I found both parts available online. What advantage is there to use the kit mentioned to solve the problem.
jacuba is offline
post #2 of 10 (permalink) Old 08-18-2010, 03:59 PM
I am sure someone will correct me if I am wrong. The fan is supposed to keep running when the key is off. The circuit for the fan is live no matter what the position of the key is. Try letting the fan run and see if it turns off on its own once it cools off. I know mine does.
JAKE JANACEK is offline
post #3 of 10 (permalink) Old 08-18-2010, 05:09 PM
This happened to mine once...its supposed to run until its cool after the key is off...i tapped the sensor thats attached to the radiator on the driver's side with the handle of a screw driver and its worked fine ever since...i guess it was stuck or something...i'm still on the fence about adding a water temp gauge and a switch just to backup the system...because i dont trust it...if it can stick on, it can stick off and cause the fan to not come on at all.
Gr3G is offline
post #4 of 10 (permalink) Old 08-18-2010, 08:52 PM Thread Starter
Yes normally the fan would run with the ig sw off for a couple of minutes after riding in hot weather and then shuf off, but lately it keeps running and running even though the weather is cooler. It ran for 15 minutes the other day until I disconnected the battery. I hooked the battery back up five minutes later and the fan did not run. I have never had to add coolant and its on the full mark. I have about 1,400 mi on it.
jacuba is offline
post #5 of 10 (permalink) Old 08-19-2010, 06:26 AM
Probably temp switch
post #6 of 10 (permalink) Old 08-23-2010, 03:30 PM
The fan runs until cool even without the key in. If you have to disconnect the battery to get it to shut off then you are heading the same way I was. at first it will shut aff after you reconnect the battery, but after a few times it will always stay on. I just did Todd's kit (Hunterworks) and have had no problems since the install! Ran the hell out of this past week in the Dunes and ran without a problem.
atv4fun is offline
post #7 of 10 (permalink) Old 08-24-2010, 02:49 AM
Needs a new switch. Try tapping the switch next time the fan stays on, and it will turn off. Keep taping it instead of disconnecting the battery until you replace it.
post #8 of 10 (permalink) Old 11-03-2010, 03:57 PM
i have a 2009 and when i turn the ignition off the fan turns off as well. Is this normal or should it stay on until the temp switch shuts it off?
scff1781 is offline
post #9 of 10 (permalink) Old 11-04-2010, 07:36 AM
eez
mine shuts off with key as well, it will run with key in on position bike not running but turn off and fan shuts off, wondering now if this is coorect?? If not whatcha think is culprit
eez is offline
post #10 of 10 (permalink) Old 11-04-2010, 10:43 AM
My 2010 Sport does the same thing....I'll keep on eye on it but I know it's been running with the key on, then turn the key off and it stops.
shanny55 is offline
cooling fan breaker crab Kawasaki Teryx Electrical Discussions 5 07-08-2010 11:43 AM
Cooling Fan Issues !! TeryxMasher Kawasaki Teryx General Discussions 4 01-06-2010 10:57 PM
Cooling Fan Issues !!!! TeryxMasher Kawasaki Teryx Electrical Discussions 3 12-27-2009 10:51 PM
cooling the teryx codyo Kawasaki Teryx General Discussions 9 12-18-2009 08:10 PM
Cooling fan won't shut off! Junior Kawasaki Teryx Electrical Discussions 0 07-23-2009 10:58 AM
