2008 ignition problem - Kawasaki Teryx Forums: Kawasaki UTV Teryx Forum
Kawasaki Teryx Electrical Discussions Kawasaki Teryx electrical discussions.
Lighting, audio, GPS, communications, etc.
post #1 of 5 (permalink) Old 04-04-2013, 10:33 PM Thread Starter
I have an 08 all stock Teryx that recently just seemed to have lost a lot of power. It sounded like it was only running on one cylinder so I started checking for spark. While it was idling I pulled the back spark plug wire off and the engine died immediately. Started it back up and did the same thing with the front plug wire and it kept running. I switched the spark plug/coil wire from the front to the back and I got the same results so it appears I'm only getting spark to the back plug. Does anyone know what the voltage should be to the spark plug/coil wire? I noticed what I assume is the coil has a positive and negative sign. Also I was looking at a parts list from Kawasakipartsnation.com and it looks like there is a part called an igniter, part # 21119-0092 and was wondering is this what feeds the power to the coils? and if so could that be the problem?
greenone is offline
post #2 of 5 (permalink) Old 04-07-2013, 07:57 PM Thread Starter
Just in case anyone has the same problem I had. I went to a Kawasaki dealer and they had a service manual that said the voltage to the coil is only about half a volt which mine did measure out to be. Also, I didn't realize what Kawasaki calls an igniter is the CDI. Anyway the mechanic said not to rule out that the spark plug could be partly fouled which they both were black when I removed them. Even though I took the original spark plugs and switched them, it seemed to run the same and it end up being a fouled plug. I replaced the plugs and it ran great.
greenone is offline
post #3 of 5 (permalink) Old 04-08-2013, 07:04 AM
Sometimes the wires connecting the 2 coils get loose or corroded.
post #4 of 5 (permalink) Old 04-08-2013, 11:21 PM
I was going to say that you needed to try some new plugs, then I read your second post and see that you figured it out already. It's best to start with the simple things first before you get way to involved.
post #5 of 5 (permalink) Old 12-09-2015, 11:46 PM
Quoted: 2 Post(s)
Thanks for the information i will do as u said.
Roger smith is offline
msd ignition ccartl6688 Member Introductions 2 05-15-2011 07:24 AM
Ignition question Camo08 Kawasaki Teryx General Discussions 9 09-23-2010 10:29 PM
looking for a ignition wire Tysonh Kawasaki Teryx General Discussions 0 06-03-2010 09:36 PM
2008 teryx dragonfire ignition g-force Misc Items For Sale 2 03-15-2010 01:31 PM
Dyna ignition wfobogger Kawasaki Teryx Performance Discussions 3 12-11-2009 07:51 AM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72
