I have a 2013 Teryx 4. I can jump start it, it will run for a couple minutes then the EPS light comes on and power steering won't work, within seconds the check engine light comes on and the motor stops. The battery is brand new. Please give me some ideas on what to check or what might be wrong. Thanks.
Hello , mine is doing this also. Replaced the battery , drove for a couple days, same issue. Did u ever find anything out ? Or do I need a bigger battery?
Mine was the battery. I learned a bunch of components on these things rely on a constant small but solid pull off the battery. Even if your battery is new I would check it out thoroughly before moving on.
This. Had the same issue with mine. EPS stopped working, but IIRC everything else functioned properly. Replaced it with a good odyssey battery and never had another problem.
I had the exact same issue about a year ago on my 2013 Teryx4. I replaced the battery and in a couple days later the problem returned. My stator was bad and had to be replaced for $700. Fast forward a year and a half later and today I am back at Kawasaki for another new stator, voltage regulator, and a complete new wiring harness. $3385.57. The technician said he was on the phone with Kawasaki for four hours before diagnosing the problem. The wiring harness lost its ability to carry the voltage and the charging system was working so hard it killed the stater and regulator. The technician told me that he has at least two other machines with the exact same problem right now. One is a 2013 model and the other is a 2014. Since this work was done at Kawasaki, the parts and labor have a one-year warranty. But you can bet the buttons on your shirt that this piece of junk will be out of my hands within a year.
p.s. I found this thread because I took off work and drove over an hour to pick up my machine and the power steering doesn’t work. There’s no EPS light on, no codes, and the technicians are at a loss so I’m searching the Internet to see what I can find.
Has anyone heard of any kind of recall on this problem ? I'm going on my second stator replacement and thinking about selling and going with a different machine.
I know this is an old thread but if you have any fixes please share
Related Threads
Teryx HQ
57.2K posts
11.5K members
Since 2008
A forum community dedicated to Kawasaki Teryx UTV owners and enthusiasts. Come join the discussion about racing, performance, suspension, modifications, classifieds, troubleshooting, maintenance, and more!
