neutral light adjustment? - Kawasaki Teryx Forums: Kawasaki UTV Teryx Forum
post #1 of 12 (permalink) Old 12-13-2008, 02:21 PM Thread Starter
how do you adjust the linkage so the neutral light will stay on? my light works with the cowl off,but when i put it back on the light goes off
puddle jumper is offline
post #2 of 12 (permalink) Old 12-13-2008, 04:45 PM
Weird??
Are you certain nothing is pushing down on the neutral wire into the tranny. The only reason I ask this is because....it did the same thing to me, and took me a while to figure out, whenever I put the cowling back on it was pushing into my heat shield which was grounding out and pushing down into the wire...just a thought. Seems like it has to be pushing down into something though. Unless, there is some wire covering melted off somewhere else grounding out the neutral wire.?.?
post #3 of 12 (permalink) Old 12-13-2008, 07:08 PM Thread Starter
im not really sure.with the cowl on i can move the shifter over to get the light to come on but it s pita to start everytime pushing the brake
post #4 of 12 (permalink) Old 12-13-2008, 07:23 PM
waytay's Avatar
MIne needs adjustment also wont start unless I push over a clit hair??
waytay is offline
post #5 of 12 (permalink) Old 12-13-2008, 09:10 PM
Well now I am glad you all brought this topic up, I am going to check my linkage and see if adjusting it some will help (once I find the damn place to do it) because I was going nuts trying to find where it (the wiring) was shorting out. You must be on the right track though because some days it is just fine then probably one or two days I have the same problem, either gotta move my shifter a little or push on the brake to start in neutral.
My teryx caught fire after about 20 hours and I had to replace lotsa wiring, and with my other problem...the heat shield pushing into the neutral wiring...I was assuming it was still in the wiring somewhere. Since you guys have the same problem it must be in adjusting the linkage? That's what my dumbass gets for assuming. Anybody out there ??? give me some help on where to adjust the linkage?
post #6 of 12 (permalink) Old 12-14-2008, 08:24 AM Thread Starter
just adjusted mine.theres a nut on each end of the shift linkage,loosen them up and turn the linkage for the light to stay on in N
post #7 of 12 (permalink) Old 12-14-2008, 10:04 AM
Thanks for the follow-up Puddle Jumper.
post #8 of 12 (permalink) Old 12-14-2008, 09:04 PM
you can adjust the shift linkage on the right side, it adjusts just like a tie rod. mine needs constant adjustment. if it gets out of adjustment the tranny can start popping out of gear and thats big trouble!
redle is offline
post #9 of 12 (permalink) Old 12-14-2008, 09:18 PM
Mine pops out quite often.....well......only when I need another drink of beer...!!!
post #10 of 12 (permalink) Old 12-15-2008, 11:08 AM
I just did this, my neutral light would come on half way between neutral and high. The adjustment is in the linkage, loosen the two nuts and turn the shaft to get the neutral light in the correct position and then tighten the nuts. Super easy.
djkelsoe is offline
Reverse Light pigtail Rutcutter Kawasaki Teryx Electrical Discussions 22 02-03-2015 10:31 AM
After Market Light Wiring Diagram T-REX How-To's 9 01-11-2010 11:39 PM
Dome Light zuli Kawasaki Teryx Electrical Discussions 5 01-01-2009 05:56 PM
