Easy Fuel Sender install - Kawasaki Teryx Forums: Kawasaki UTV Teryx Forum
post #1 of 7 (permalink) Old 02-13-2009, 11:42 PM Thread Starter
Taking the gas tank out, draining the fuel and so forth is a lot of trouble. I came up with this and you don't have to remove the tank and the gas can stay in.
Get a hole saw the size you need for your sender, set the center drill bit just below the hole saw, start drilling into the top of the tank but don't let the drill bit or hole saw go all the way thru. When it is getting really close, stop then screw a screw into the drill bit hole, hold on it it then finish cutting the hole out with a utility knife.
Nothing falls into the tank. Set your sender down in the tank and use some wood screws to hold the sender.
Worked out great for me!!
post #2 of 7 (permalink) Old 02-13-2009, 11:55 PM
Great idea. I have been putting off installing mine for this very reason. I will try it out and see how it works. Thanks to [email protected] again!!!!!!
ultimate1 is offline
post #3 of 7 (permalink) Old 02-14-2009, 09:22 PM
I am still looking for a source for the sender and gauge. Asked once before but no response, More importantly for me would be finding the volt meter gauge I read about in the tech articals on the Hunter Works site, Any clues or info Todd?
grey goose is offline
post #4 of 7 (permalink) Old 02-16-2009, 02:10 AM
If you do a search you can find the info. I used a hardin marine sender from cp performance along with autometer gauges. There are many tech articles with pictures on this I believe.
post #5 of 7 (permalink) Old 02-16-2009, 06:06 AM Thread Starter
Grey Goose,
I use generic 2 1/16" gauges like Autometer from summit racing.
post #6 of 7 (permalink) Old 02-18-2009, 05:30 PM
If you put a little vaseline or grease on the hole saw before you drill, it will grab all those little plastic fileings instead of them going in the gas tank. I would also hold a vacuum hose near the saw when drilling. Use stainless steel screws to hold the sender with some permatex gasket sealant (gasoline resistant) on the gasket and tank.
fireguy266 is offline
post #7 of 7 (permalink) Old 02-18-2009, 06:18 PM Thread Starter
I never drilled thru with the hole saw.
Easy Oil Change! Teee-rible Kawasaki Teryx General Discussions 5 04-01-2009 01:10 AM
fuel guage kingforce Kawasaki Teryx General Discussions 20 02-13-2009 07:00 PM
fuel pump? puddle jumper Kawasaki Teryx Performance Discussions 2 09-21-2008 08:16 PM
Easy gas tank removal and installation teryx2378 Kawasaki Teryx General Discussions 1 08-25-2008 07:40 PM
Fuel Gauge dieselpowered Kawasaki Teryx General Discussions 9 03-05-2008 12:44 AM
