what started fire???? - Kawasaki Teryx Forums: Kawasaki UTV Teryx Forum
post #1 of 17 (permalink) Old 02-28-2009, 10:17 AM Thread Starter
sandmankrohn's Avatar
the dealer called and said they can not figure out what started the fire..... I am attatching a couple pics . 1 is 1 of 2 peices of burnt rubber I found under the front exhaust tube on the skid plate. the other is a pic down between the shifter and the plastic ( pulled back) you can see the melted hole in the vent, melted throttle cable, melted plug wire, etc.... sorry about the sand..... just started dumping sand on it to put fire out....... oh yeahanybody know where to get a compact fire extinguisher at a descent price only one I can find in my small town in at the parts store of $90... I thought that was a little unreal but if thats what the compacts go for???!
ID:	939   Click image for larger version
sandmankrohn is offline
post #2 of 17 (permalink) Old 02-28-2009, 10:53 AM
That is a rubber protector / shield (for lack of better words), there are a couple of them around the machine. Look behing your seats, you will see one on either side attached to the bed to cover the gap.
post #3 of 17 (permalink) Old 02-28-2009, 05:31 PM
jcummins's Avatar
Bet you got something burnable on to the front header. I get trash caught there and had an almost serious fire there…but also had several ‘smoking’ issues of trash smoldering off the header. Seems to me to be a bit of design issue.
jcummins is offline
post #4 of 17 (permalink) Old 02-28-2009, 05:35 PM Thread Starter
oh guess I should have said..... I just baught it was 10 min into first ride... has all dragonfire bolt on mods done by shop here in oregon (not dragonfire tech)
post #5 of 17 (permalink) Old 02-28-2009, 09:03 PM
Spiderwebs..probably., Last person OBVIOUSLY did not ride it..(it had been sitting)...or they wouldn't have sold it!!!!! Yep, my vote is for spiderwebs.
Ya know I'm just kidding, I also owned a burnt Tearex!!!
post #6 of 17 (permalink) Old 02-28-2009, 09:10 PM
Rhino Stomper's Avatar
Go to Kartek, they have the 2.5 lb for like $35 or so...red, not chrome...thats more.
Sorry bout your ride!! Time for some heatshield upgrades!!
SDR 4 seater cage, LT6 suspension w Fox shocks, F & R Basher Bumpers, Lightbar w 4 fuego HID's, Roundeye LED Rocklights, SafeGlow LED whip, Lowrance Baja 540c, UNI
Rhino Stomper is offline
post #7 of 17 (permalink) Old 02-28-2009, 09:31 PM
Having said that....here is our earlier link to this.....
http://www.teryxhq.com/forums/kawasa...1151-fire.html
I have seen one of my buddies run over a small potato chip bag, it stuck to his header or pipes somewhere and it caught fire, and started a fire on his shrouding.
My fire was related to sticking my T-shirt down the side of the seat and trying to cover up the heat from the center console, forgot about it and high tailing down the road...we smelled smoke. Shirt had sucked between the bed and cab....and shirt touched the header....needn't explain anymore...
The location where yours seems to be....in my opinion....appears to be from debris building up there.
I bought a $5.99 small spray can fire ext and put in glovebox (it's about the size of those Canned air dust removing type of spray), I also mounted a $19.99 fire ext from Lowes, on the rear of my rollbar, hopefully...will never need it.
post #8 of 17 (permalink) Old 02-28-2009, 10:08 PM
Yep I agree debris from some sort, either from shop installing parts or from mother nature. Back here in the eastern woods I noticed several times that mine or one of my buddies teryx had a glowing red area in the motor area down low. Upon further inspection we found dry leaves in there on fire, luckily they burned themselves out before causing any damage.
08' Teryx LE, FST 840, Muzzys, VDI, Dalton, VFJ Roller, Thunderhawk Performance Race Cage, Bumpers, Door Bars and Bracing, Beard TSX Seats, 5pt. Crow Harness, 12" ITP Type 7 Beadlocks, GBC 8 ply Dirt Commanders, Pro Armor Skids, Team Green Plastic
08' Teryx, Maier Orange Plastic, Thuderhawk Performance 4 Seat Cage, Bumpers, Door Bars and Bracing, Beard TSX Seats, 4 pt. Harness, 14" Chrome Doughas Diablos w/GBC Grim Reapers, VDI, Dalton
xchamp is offline
post #9 of 17 (permalink) Old 03-01-2009, 12:38 AM
1Txn's Avatar
Walmart sells fire extinguishers pretty cheap.
1Txn is offline
post #10 of 17 (permalink) Old 03-01-2009, 01:26 AM Thread Starter
wow didn't think about debris geting stuck in there.. not the issue with mine though .... it was brand new just put together
I thought about the cheap say walmart extinguisher but the always have a cheesey mount. will try kartech thanx
oh I got the 2.5 ld extinguishers with nice metal mounts: 1 from the saw shop and 1 was given to me by a rhino dude named Mark-O- that heard about my fire..... so even rhino guys are cool... just not as fast...... sorry mark-o- you know it's true
Last edited by sandmankrohn; 03-14-2009 at 10:25 PM. Reason: added extinguisher info
What do you need to get started? DougS Getting Started 14 02-24-2010 07:14 PM
Fire jcummins Kawasaki Teryx General Discussions 11 10-08-2008 08:37 PM
HW finally started on exhaust test and clutch Hunterworks Kawasaki Teryx Performance Discussions 12 09-06-2008 07:56 PM
Crown King, AZ On Fire dieselpowered Southwest Region 2 07-01-2008 06:26 PM
Finally got it and started getting it ready!!! hitman2565 Kawasaki Teryx General Discussions 8 05-25-2008 09:42 PM
