Quick tire question - Kawasaki Teryx Forums: Kawasaki UTV Teryx Forum
post #1 of 6 (permalink) Old 03-10-2009, 09:58 AM Thread Starter
AXO
AXO's Avatar
Smile Quick tire question
I am ready to buy new rims and tires. My question is will 28x10x12 front and 28x12x12 rear fit on my 09 Teryx Sport without a lift kit and rubbing issues?
Secondly which rim do you prefer?
ITP ss312's or Motosport Alloys black Torks?
Thanks Jeff
Lifes a Garden Dig it!
AXO is offline
post #2 of 6 (permalink) Old 03-10-2009, 01:28 PM
I am pretty sure they will fit, I am running 27x9-14 fronts & 27x11-14 rears and I know I could put on a 28" and will clear. The 12" rims are 7" wide front and rear, the 14" are staggered - 6" front / 8" rear. I don't know if this will make it rub on the front, the rears should be fine. I was going to go with 28" on mine originally but wanted the radial XTR's so bought 27's. They clear fine front and rear even in the rough stuff! Good luck!
The rims look good to, I didn't know they had that rim out, I bought the SS212 in chrome.
post #3 of 6 (permalink) Old 03-10-2009, 09:00 PM Thread Starter
AXO
AXO's Avatar
Thanks Junior, I am going to order the 28's. I'll let you how they turn out. I found the best deal at ATV Tires, ATV Tire Wheel Kits, Sport Wheels, Street Tires, Sand Paddles: Moto X Mall.
AXO is offline
post #4 of 6 (permalink) Old 10-09-2009, 10:05 PM
I need some information on wheels. How much difference in width will a "wide trake" (-47mm) set up vs std off set wheels? Will this significantly change the steering effort or put too much stress om a stock front end? Just bought a cage and seat package. Wheels and tires are next then looking at power steering.
crawfish is offline
post #5 of 6 (permalink) Old 10-10-2009, 10:19 AM
$kidoo's Avatar
28" Mudzillas fit on stock rims/teryx with no rubbing on the frame.I spaced out the front tires 1/4 " with washers because the tire was hitting the tie rod.
230 Hours
Standard Muzzy duals
Hunterworks Carb Kit
Dynatek C.D.I.
Uni Filter
Dalton Clutch Kit and O.D. Cover
Kolpin Dual Gun Holders
Warn XT 3000 Winch
Custom Cut Lexan Windshields
Guages Water/Gas/Volt
soon to be fabbed
4 seat cage with removable boat rack
http://www.teryxhq.com/forums/kawasa...shields-3.html
$kidoo is offline
post #6 of 6 (permalink) Old 10-10-2009, 11:25 AM
I don't really understand what you mean by ' wide track '? Are you just using wheel spacers or is it a long travel kit, if you are spacing it then yes you put more stress on the front end because the leverage increases between the tire and your ball joints (you are moving your wheel out but not the pivot point), it will make your steering a little harder and tends to pull a little more, kind of like oversteering.
As for the -47 mm offset, this means you are moving your wheel out, sounds like a 1 3/4" spacer.
Hope this helps or makes sense!
Quick Update from Buttercup Effinbees77 Kawasaki Teryx General Discussions 8 12-02-2008 12:24 AM
Wiring Quick Disconnects dieselpowered Kawasaki Teryx Electrical Discussions 9 10-16-2008 12:07 AM
New DFR Quick Release Steering Wheel DRAGONFIRERACING Kawasaki Teryx General Discussions 2 09-24-2008 04:07 PM
Quick and Dirty 20 hour service T-REX How-To's 7 07-08-2008 09:58 AM
Quick Release Steering Wheel dieselpowered Kawasaki Teryx General Discussions 17 05-24-2008 11:53 AM
