Still having Dalton Clutch adjustment Problems. - Kawasaki Teryx Forums: Kawasaki UTV Teryx Forum
post #1 of 18 (permalink) Old 04-04-2009, 02:32 PM Thread Starter
Cuzin Eddie's Avatar
So as most of you know I have not been happy with my clutching problems. I had my dealer install the Dalton kit and it has not worked very well since they finished it. Please understand I don't think that the Dalton kit is the problem. Come to find out that they used the STOCK primary spring and now I don't know if the secondary spring is the STOCK or the Dalton Spring. So is the shiny silver one the stock spring or is it the dull silver with white paint the stock one????????
I think I need to change the spring and I think I need to take the small shim out. The reason is I set up the Primary clutch to the exact specs from Dalton and went to the Kawi dealer and raced a stock Teryx and got spanked and I mean spanked!!!!!!!! So would my 1 1/2" deflection belt cause that or is secondary spring causing that????????
I just need help. Any opinions would be greatly appreciated. Also, please understand I do relize the help that I have previously had and I am grateful!!!!!!!!!
2009 Monster Sport l
Seven Oaks Fine Jewelers
"It's okay to throw our ROCKS at Girls"!!!!
(435) 901-3307
Cuzin Eddie is offline
post #2 of 18 (permalink) Old 04-04-2009, 02:46 PM
Have you emailed Dale (Helix) at Dalton yet?
I think your belt could be tighter.
Did the dealer "pull on over your eyes" and charge you for a cheaper clutch kit or by mistake installed the wrong one?
Here is a picture of thier kit from Dalton
Link to Dalton
As per spanked.
Have you added a bunch of weight to your Teryx. (ie cage, 4 seats, etc?)
Both have same mods?
Metal and white line is a Brute Force 650 spring. I think they may have put the wrong kit in.
Scroll down on the link I sent you.
post #3 of 18 (permalink) Old 04-04-2009, 02:46 PM Thread Starter
Understand though that even with the belt having to much deflection it does not seem to slip. The thing that I did notice is the jerking of the Secondary Clutch. If you give it a little throttle the secondary clutch jumps and jerks.
(435) 901-3307
post #4 of 18 (permalink) Old 04-04-2009, 02:59 PM
Added more stuff to the post above. Did you see the spring by the 650? Is that the one you have?
post #5 of 18 (permalink) Old 04-04-2009, 03:39 PM Thread Starter
Link to Dalton
As per spanked
Dougs
Hard to tell by the pictures on the spring, however I do have a 4 seat cage and some other heavier stuff.
thanks for the info!!!!!!
(435) 901-3307
post #6 of 18 (permalink) Old 04-05-2009, 09:29 AM
poflo's Avatar
If you you have too much belt deflection,it is like trying to start in a higher gear,the primary clutch is engaged at a higher ratio,when it takes the slack out of the belt;if your secondary spring is too weak,that sometimes signals that the belt is slipping in the secondary pulley by by jerky motion.;which can be caused by trying to take off in the effective higher gear ratio that was created by the loose belt .Sounds like you have more than one problem
poflo is offline
post #7 of 18 (permalink) Old 04-05-2009, 12:58 PM Thread Starter
Last night I took the Secondary clutch apart and took the thin shim out and put the Dalton spring in since the dealer had accidentally put the stock spring back in. All I can say is WOW on what a diff it made on where the belt rides on the Secondary clutch now compared to where it was before and to think that that small shim made that much difference.
I have not driven it yet... I will tomorrow and let everyone know the difference. All I can say is I am so glad (for now) that I attempted to do this adjustment myself and to learn from all the knowledgeable people here on this forum. I am truly grateful for all the insight that you good people have offered to me.
Thanks again-
Shane
(435) 901-3307
post #8 of 18 (permalink) Old 04-05-2009, 07:54 PM Thread Starter
Okay, so I just got a wild hair and took the Teryx out for a small ride it was killing me to see if the adjustments worked. I still don't have the throttle response that I want. It probably takes about 1 to 1 1/2 secs to engage. I definitely have the belt right and I have the amber spring in the Primary and the silver in the secondary. I have alum rivets and I have 2 set screws. It also seems that the RPM's are much higher when it engages.
Why does it take so long for it to engage????? Do I need to change the Primary spring to Orange or do I need to take some screws out or add one?????
Dang it.... now it is getting frustrating
(435) 901-3307
post #9 of 18 (permalink) Old 04-05-2009, 08:13 PM
I think you need all set screws in for a stock motor.
Takes so long to engage?? Are you easing on the gas?
Hit it and go!!
post #10 of 18 (permalink) Old 04-05-2009, 08:17 PM Thread Starter
Hit it and go!!
HW-
No I am hitting it hard. It just when I punch it takes a little while before anything happens. maybe that is the nature of the Teryx. I never rode it stock. Do they tend to have a little delay before they take off???????
At my elevation Helix said I may need 1 set screw. I am at 5,300 ft. Do I need to take the big shim out and put the little one back in???????
By the way I need to order a lift kit from you. I will call tomorrow.
Thanks HW!!!!!
(435) 901-3307
Teryx clutch kits Dalton or EPI ? Blurryvision Kawasaki Teryx Performance Discussions 71 09-12-2010 03:04 PM
Dalton Clutch Kit helix Kawasaki Teryx Performance Discussions 23 07-07-2010 07:58 PM
Dalton clutch tuning BRET901 Kawasaki Teryx Performance Discussions 14 01-05-2009 02:22 PM
winner of Dalton Clutch 4ever Kaw-Man Kawasaki Teryx Performance Discussions 2 12-06-2008 05:17 AM
Dalton clutch aviablie RomDOGG Kawasaki Teryx Performance Discussions 8 11-17-2008 09:47 PM
