750 Teryx 2008 - Kawasaki Teryx Forums: Kawasaki UTV Teryx Forum
post #1 of 11 (permalink) Old 06-20-2009, 09:07 PM Thread Starter
750 Teryx 2008
Belt sqealing only on take off. Just started after 90 hrs.
Belt loose or too tight?
grizz663 is offline
post #2 of 11 (permalink) Old 06-20-2009, 10:15 PM
got me beat, mine is sqealing like mad with only 26 hours.....
sounds like its prolly too loose.
post #3 of 11 (permalink) Old 06-21-2009, 07:21 AM Thread Starter
Teryx belt squeal on take off
The belt or clutch squeals only on acceleration High low and reverse. ANY ideas
grizz663 is offline
post #4 of 11 (permalink) Old 06-21-2009, 08:38 AM
Test the deflection. If you want the squeal to go away, you are likely going to have to take the covers off anyways.
post #5 of 11 (permalink) Old 06-21-2009, 08:44 AM Thread Starter
The deflection exceeds 22mm to 27 mm. This is removal of shims or is there a tension adjuster?
grizz663 is offline
post #6 of 11 (permalink) Old 06-21-2009, 04:53 PM
shim removal time. Set aside 2-3 hours to get it done.
DickWeed is offline
post #7 of 11 (permalink) Old 07-27-2009, 07:14 PM Thread Starter
Belt squeal
Tested the deflection it is way off. to remove the shins is on the primary??
How many shims?
grizz663 is offline
post #8 of 11 (permalink) Old 07-27-2009, 09:50 PM
Depends on the how much deflection for which shim.
Back clutch, you will likely need pullers and some time.
post #9 of 11 (permalink) Old 07-31-2009, 01:24 PM
If the belt is squeeling when the unit is parked your belt is to tight
Hava is offline
post #10 of 11 (permalink) Old 08-02-2009, 07:42 AM
if its squeeling while in gear its to tight.if your talking about if chirping when you take off in high its to loose.if its to loose you have to take the secondary clutch off and remove the small shim of the two and it will fix it.if its tight i wouldnt worry about it because it will loosen up
puddle jumper is offline
Afe intake kit for teryx 750 UTV CRAP Kawasaki Teryx Performance Discussions 0 09-12-2008 11:31 AM
Teryx 750 console heat problem nobodysguess Kawasaki Teryx General Discussions 2 06-24-2008 04:21 AM
