New guy with a problem - Kawasaki Teryx Forums: Kawasaki UTV Teryx Forum
post #1 of 9 (permalink) Old 08-21-2009, 05:52 PM Thread Starter
Just picked up my 2008, I have 6 hours on it. Just whent out to start it and it will not turn over. The fuses and breaker are fine, tried to jump start it and no change. The lights come on with no problem. I hear a solid tone and something turning after I shut it off. I'm guessing its not a big deal that I am just missing something simple.
Thanks in advance for the help.
rschroed1 is offline
post #2 of 9 (permalink) Old 08-21-2009, 08:36 PM
try to bump the stick shift around might be the switch in the linkage
post #3 of 9 (permalink) Old 08-21-2009, 09:41 PM Thread Starter
I tried that, still nothing.
post #4 of 9 (permalink) Old 08-22-2009, 07:41 AM
Just got to start checking voltage, see if you are getting it at the starter when in start position then work backward to solenoid etc.
post #5 of 9 (permalink) Old 08-22-2009, 09:05 AM Thread Starter
I'll check that, Thanks.
post #6 of 9 (permalink) Old 08-22-2009, 09:59 AM Thread Starter
Smile got it started
I pushed hard on the brake and it started, I guess that bypasses the nuetral switch. thanks
post #7 of 9 (permalink) Old 08-22-2009, 10:45 AM
i have never had to push on my brake at all
post #8 of 9 (permalink) Old 08-23-2009, 07:26 AM
Adjust your brake switch one and then look at your neutral switch for cranking in neutral.
post #9 of 9 (permalink) Old 08-23-2009, 07:53 AM
IF you leave it in gear you can start it by holding the brake. Switch or linkage should fix it, probably linkage.
Work the shifter a little bit on both sides of the N position and see if you can get it to start. This will give you a good idea of which way it needs to be adjusted.
Muzzy problem Teryx SxS 01 Kawasaki Teryx Performance Discussions 26 07-04-2009 05:07 AM
Problem with clutch kit Hunterworks Kawasaki Teryx Performance Discussions 7 12-07-2008 03:42 PM
Clutch Problem mikec570 Kawasaki Teryx Performance Discussions 6 11-25-2008 04:05 PM
Houston We Have A Problem dieselpowered Kawasaki Teryx General Discussions 13 10-20-2008 08:11 PM
Brake Problem?? There one time gone the next buckshot Kawasaki Teryx General Discussions 8 06-21-2008 11:50 AM
