Oil - Kawasaki Teryx Forums: Kawasaki UTV Teryx Forum
post #1 of 35 (permalink) Old 11-01-2009, 01:56 AM Thread Starter
Oil
What oil does everyone use in their Teryx.,.. it is now getting cold here, so I will run a little lighter oil. Do you recommend a multigrade such as a 5 30 or the like? Or should I go and get some amsoil, or synthetic?
morkable is offline
post #2 of 35 (permalink) Old 11-01-2009, 07:16 AM
We run Yamalube in everything.
Since the Teryx does not have a wet clutch I can't see how what oil you use makes a difference but I am sure someone will correct me on that.
Go with what your manual says.
post #3 of 35 (permalink) Old 11-01-2009, 07:45 AM
SRX
SRX's Avatar
I'm using Rotella straight 40, will go with lighter straight or multi soon. Not going snythetic as I change it often and it's using about 1/4 qt per 175 miles. Don't know what happened since BBK it's done this.
08 LE,840 BBK,mild porting, std Dyna,HW jet kit,Uni filter,crap OD Cap,EPI Clutch Kit,Coolie,Muzzy's,ceramic pipes,SS112's,BigHorn 2.0's If It's stock it Sucks!
SRX is offline
post #4 of 35 (permalink) Old 11-01-2009, 08:31 AM
I use 10w40 year around.
Could be the 40w oil as for using it.
Could be a installation error like not getting the rings spaced around correctly or not broke in.
Could be valve seals
Could be getting sucked into intake
post #5 of 35 (permalink) Old 11-01-2009, 11:29 AM
Just a 1/4 is probably it puking oil and even with a catch can some is making it back into the intake and burning it under high loads/hills where you would never really see it. Wouldn't worry yourself over it really.
I run 15-50 or a 20-50 in the summer time but in winter time usually just a 10-40...
post #6 of 35 (permalink) Old 11-02-2009, 01:46 PM
$kidoo's Avatar
I run 5w-30 synthetic all year.It doesnt get hotter than 25c up here.-30c in the winter.No problems yet.
230 Hours
Standard Muzzy duals
Hunterworks Carb Kit
Dynatek C.D.I.
Uni Filter
Dalton Clutch Kit and O.D. Cover
Kolpin Dual Gun Holders
Warn XT 3000 Winch
Custom Cut Lexan Windshields
Guages Water/Gas/Volt
soon to be fabbed
4 seat cage with removable boat rack
http://www.teryxhq.com/forums/kawasa...shields-3.html
$kidoo is offline
post #7 of 35 (permalink) Old 11-02-2009, 06:05 PM Thread Starter
Hey Skidoo, what brand of synthetic are you using? Its 2.4 us quarts right? Does anyone happen to know what that is in litres?
morkable is offline
post #8 of 35 (permalink) Old 11-03-2009, 11:17 AM
$kidoo's Avatar
Im using motomaster (canadian tire) synthetic.I realy want to try amsoil 0-30
From the teryx manual
2.1 L (2.2 US qt)
(When filter is not removed)
2.2 L (2.3 US qt)
(When filter is removed)
2.3 L (2.4 US qt)
(When engine is completely dry)
230 Hours
Dynatek C.D.I.
Uni Filter
Warn XT 3000 Winch
soon to be fabbed
$kidoo is offline
post #9 of 35 (permalink) Old 11-03-2009, 08:18 PM
You need to run an oil that can withstand the stress of the gearbox...Unlike automotive engines (and even if there is no wet clutch) the engine oil also lubricates the transmission (common sump design). Yes all SxS have a gearbox (high, Low and Reverse gearing)...don't confuse this with the CVT belt which is the converter system from the engine to geared transmission. Automotive engine oil is not designed to work inside gearbox, but simply inside the engine. ATV/Moto/Snowmobile oil is designed to be able to withstand the gear pressure and not break it's film strength, which would cause metal to metal contact. This is why you can use ATV/Moto oil in the front diff of the Kawi and not gear oil.
Diesel oil typically does not contain friction modifiers (which cause wet clutch slip), but it also isn't designed to work inside a gearbox.
Full synthetics will drop your engine operating temp and also provide better protection against oxidation, viscosity loss and high shear strength.
You need to stick to the OEM recommended 40 weight, so a 0W-40 or 10W-40 ATV/Moto 4 stroke oil would be my recommendation.
post #10 of 35 (permalink) Old 11-03-2009, 08:31 PM
I'm not the one to ask, I will run about anything in them but we use yamalube in the shop.
I can't the difference in one or another on anything. Run my race rhino as hard as any vehicle, no oil related issues yet.
