Starting issues - Kawasaki Teryx Forums: Kawasaki UTV Teryx Forum
post #1 of 13 (permalink) Old 11-16-2009, 07:19 PM Thread Starter
RJB
Starting issues
Have an 09 teryx 68 miles and it is great. On initial start up in morning 0 degrees celcius It will start run for a few secounds and stop. Try starting again and it wont fire until i touch the throttle. When the motor is warm it starts great. Fuel injection should not have to touch the throttle. Anyone else have this problem.
RJB is offline
post #2 of 13 (permalink) Old 11-16-2009, 07:24 PM
I have mine shut down and need to be restarted but never had to touch the gas for it to fire up
h0tr0d18 is offline
post #3 of 13 (permalink) Old 11-16-2009, 09:32 PM
coondog's Avatar
Dude !!!!!!!!!!! 0 degrees celcius!! no motor is going to want to start right up.
coondog is offline
post #4 of 13 (permalink) Old 11-17-2009, 06:03 AM
That's just 32 degrees but it is nothing I would worry about. They all have quirks.
post #5 of 13 (permalink) Old 11-17-2009, 06:15 PM Thread Starter
RJB
800 can am starts at - 30 celcius 0 isnt that cold dude!!
RJB is offline
post #6 of 13 (permalink) Old 11-17-2009, 06:30 PM
crow's Avatar
When I was looking for my t rex, I test drove a 09 & 08. The 08 started right up & idled with the choke, the 09 started up and died 3 or 4 times until I put my foot on the throttle. Salesman said that was the way all the 09s are. I needed a machine to start & run at cold temps so I bought a 08 model. I wish the fuel injection worked in the cold better as I have changed the air filter & intake so now jetting is required. Crow
crow is offline
post #7 of 13 (permalink) Old 11-17-2009, 06:53 PM
With the 09s you should turn the key on and let the fuel system prime. You can hear the pump running untill it builds pressure, then start the motor.
FUELATV is offline
post #8 of 13 (permalink) Old 11-17-2009, 07:06 PM
crow's Avatar
I should add that the 09 won't idle without my foot on the throttle for a minute or more.The temp wasn't very cold only about -15 c. Crow
crow is offline
post #9 of 13 (permalink) Old 11-17-2009, 09:06 PM
Most EFI small engines, or even automotive engines tend to overfuel at idle especially when cold. I think these things over fuel at idle and probably over fuel all the time while driving - factory settings to be safe. I don't know if anyone out there has a programmer for the EFI model and if so does it help with cold starts? Not much you can do but rev it up a little for a minute to get it warmed up a little to run better! Good luck.
post #10 of 13 (permalink) Old 11-17-2009, 11:43 PM
The PCIII and ignition module work great but are not readily available. I am sure that the PC5 would also work great. Junior you are spot on, I know on the mapping that we are taking a good amount of fuel away. Don't know the exact percentage on a stock car. I do know on the Dasa 840 build we installed larger injectors to help the duty cycle but have to take a very large percentage of fuel away!!
FUELATV is offline
Teryx not starting in the cold? $kidoo Kawasaki Teryx General Discussions 39 01-16-2011 07:47 PM
Cross Country starting Feb. 22nd Hunterworks Cross-Country UTV Racing 5 02-17-2009 09:40 PM
Strange starting issue jcummins Kawasaki Teryx Electrical Discussions 9 01-11-2009 07:05 AM
Fan Issues! Chadman Kawasaki Teryx Performance Discussions 7 12-02-2008 11:35 PM
Cold Weather Starting buckshot Kawasaki Teryx General Discussions 3 04-23-2008 03:48 PM
