question on starting bbk? - Kawasaki Teryx Forums: Kawasaki UTV Teryx Forum
post #1 of 6 (permalink) Old 01-05-2010, 04:38 PM Thread Starter
why does the instructions state that i better not let the motor idle after starting it?>
post #2 of 6 (permalink) Old 01-05-2010, 04:48 PM
Most likely because you don't get very good coolant flow on the Teryx at idle and it will heat up very quick.
FUELATV is offline
post #3 of 6 (permalink) Old 01-05-2010, 08:50 PM
If you are just now starting it for the first time, you can run it briefly, but that pertains primarily to break in. I would guess that it's tied as much to breaking in the cams & seating the rings properly, which probably needs to be done at moderate, normal operating rpm moved up and down some. Not held at a constant idle. I'm sure that there are more technical reasons, but this is what I've always been taught on car engines.
FYI, I don't know what you are using for an oil to break in with, but from what I know on cars now, all of the cam manufactures warn against using your typical motor oils for break in. There are now addititives and such that will result in a flat cam very very quickly on automotive engines that are assembled with brand new cams and standard motor oils.
crash1068 is offline
post #4 of 6 (permalink) Old 01-05-2010, 09:03 PM Thread Starter
just regualr kawasaki oil 10 40....will that be suffiecient?
post #5 of 6 (permalink) Old 01-05-2010, 11:16 PM
I'm not knowledgeable enough to tell you what will work. I only know it has to do with the addititives and it's primarily applicable to breaking in.
I run diesel oil as I've been instructed in the past (rotella 15/40) but that's not to say it's the best. Just what I've been told. I know it's a good oil that doesn't have the additives and I always have plenty of it for our equipment & truck. I know it holds up better in some of small mowing equipment as well.
My guess is that the kawi oil would be fine, but you might ask an engine builder or maybe webcam.
post #6 of 6 (permalink) Old 01-06-2010, 09:32 AM
I use the Rotella for cam break in for that reason. I can't remember, but believe it's something they have taken out of most conventional oils that may cause problems.
Don't let the motor idle while breaking in new cams. Mickey's opinion may differ, but 2000 rpm for 20 minutes should be fine.
'08 Teryx- Dyna CDI & Coils, HW Jet kit w/ TPI valves, Dalton clutch & OD plate, HID's, Muzzy's, FST 840, UNI, 4 Seat Cage, WER Shocks, 27" Bighorns & 29.5 Outlaws
dirtracer4 is offline
Teryx not starting in the cold? $kidoo Kawasaki Teryx General Discussions 39 01-16-2011 07:47 PM
Starting issues RJB Kawasaki Teryx General Discussions 12 11-22-2009 01:30 PM
Cross Country starting Feb. 22nd Hunterworks Cross-Country UTV Racing 5 02-17-2009 09:40 PM
Strange starting issue jcummins Kawasaki Teryx Electrical Discussions 9 01-11-2009 07:05 AM
Cold Weather Starting buckshot Kawasaki Teryx General Discussions 3 04-23-2008 03:48 PM
