20 hour fluid change; not bad at all..... - Kawasaki Teryx Forums: Kawasaki UTV Teryx Forum
post #1 of 27 (permalink) Old 07-01-2008, 04:26 PM Thread Starter
Did my 20 hour yesterday and everything went fairly smooth , except the gravel imprints on my back haven't gone away yet.. Just a joke!! Be careful not to lose the washer that is on the oil pan bolt, mine must have stuck to the pan and fell off in to the drip pan. I didn't even notice it until I went to pour the oil into a recycle container , and there the little bugger was.....in the bottom of the drip pan. I almost went errorless, not quite.....
nobodysguess is offline
post #2 of 27 (permalink) Old 07-01-2008, 05:12 PM
NEVERENOUGH's Avatar
Just finsihed mine also. I need to buy something to make the diffs a little easier to fill but other than that not bad.
Too much is neverenough
2003 duramax dually for towing
2004 Gearbox toyhauler 30fs
2006 limited yfz 450 mine
2003 Pred 500 wifes
1986 4trax 250R sons
1997 300ex daughter
2006 250ex daughter
2008 Teryx ours
NEVERENOUGH is offline
post #3 of 27 (permalink) Old 07-01-2008, 05:13 PM
jcummins's Avatar
I'm fixing to do this too....actually a little over due.....using it and not finding time to get to this.
Using the cross-reference oil filter list, I did just today look for a filter....and couldn't find anything but the Mobil m1108 automotive. I ignored looking for Fram, I just do not want to use them. Has anyone actually used that filter? I bought it, hope it will work.
BTW - what fluid did you use on the rear end.
jcummins is offline
post #4 of 27 (permalink) Old 07-01-2008, 06:22 PM
I used a kawi oil for the wet brake bought it at the dealer. I also used the kawi filter it was only $10. The front uses 10w40 motor oil.
2003 Pred 500 wifes
1997 300ex daughter
2006 250ex daughter
2008 Teryx ours
post #5 of 27 (permalink) Old 07-01-2008, 06:26 PM
mouser58's Avatar
Send a message via AIM to mouser58
Rear uses Tractor hydraulic 10 w. Cheaper at Tractor supply, but you have to buy 5 gallon, so I think I should have just paid the extra and gotten the little bottles.
mouser58 is offline
post #6 of 27 (permalink) Old 07-14-2008, 06:03 PM
I wouldn't use a FRAM filter in anything I own...they are very cheaply constructed. They use cardboard end caps that can become saturated with oil and fail, causing unfiltered oil to enter your motor. Buy a filter with at least steel end caps and a silicon anti-drain valve (pay a little more, but whats $4-$8 for piece of mind). There are a couple of good choices out there to be safe. I recommend WIX, AMSOIL, NAPA, Purolator, and K&N. All have steel end caps, silicon valve and use a tight filter pleat. I use WIX in both my Teryx and my quads.
The rear diff is nothing special hydralic/tractor fluid. The only problem I've heard (from customers) is that they are having a hard time find it in less than 1 gallon containers from tractor supply/repair places. Look for something that is compatable with John Deere J20(A,B,C,D) or CAT TO-2...if you need some help PM me I have it in quarts.
The front diff is whatever your putting in the motor. Kawi is SAE40 spec, so anything 40 weight will work, 0W-40, 5W-40, 10W-40
Capacity:
Engine 2.43 qts
Front 0.95 qts
Rear 1.06 qts
Hope this helps you guys out...
post #7 of 27 (permalink) Old 07-14-2008, 08:40 PM
travdude's Avatar
jcummins, I used the Mobil m1108 automotive filter too. It works.
I have not done the rear end yet cause I am waiting for my dealer to get the hydraulic/tractor fluid.
While I was doing it, I noticed that they forgot to connect the vent lines to the roll cage, and the gas tank vent line was resting on the header all cracked and melted! Yikes!
I am going to get a fire extinguisher on it before I go out again.
travdude is offline
post #8 of 27 (permalink) Old 07-15-2008, 07:21 AM
jcummins's Avatar
The Mobil filter does screw in place...I have it installed. Just not sure about the internals on the filter.
jcummins is offline
post #9 of 27 (permalink) Old 07-15-2008, 09:51 AM
Mobil filters are made by Champion Labs (not related to Champion spark plugs). I'd say the filters are good as far as quality for the "performance" model. Look out for the "encore" model as these use fiber ends caps and they combined the anti-drain and bypass valves into one. Rumor is that the "performance filters are no longer manufactured and the "encore" are the standard. If this is the case, I'd be a little weary about the "encore".
post #10 of 27 (permalink) Old 07-15-2008, 12:42 PM
So we just use Tractor hydraulic 10 w in the rear? Im at 63hrs on mine and havent done the diffs yet,guess I need to get busy.
Rutcutter is offline
Quick and Dirty 20 hour service T-REX How-To's 7 07-08-2008 09:58 AM
how to change your user name???? nobodysguess TeryxHQ Help Desk 6 06-24-2008 07:15 PM
CVT Belt Change mouser58 Kawasaki Teryx Performance Discussions 0 06-13-2008 03:46 PM
20 Hour service $190 Huh? Teee-rible Kawasaki Teryx General Discussions 12 05-25-2008 01:35 PM
Hour Meter dieselpowered Kawasaki Teryx General Discussions 3 03-07-2008 12:05 AM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77
