Rims! - Kawasaki Teryx Forums: Kawasaki UTV Teryx Forum
post #1 of 5 (permalink) Old 03-17-2011, 11:06 AM Thread Starter
jfilion's Avatar
Question Rims!
I'm looking at picking up a spare set of rims to mount my Stocker tires on. I know a few guys getting rid of Can Am rims (Outlander). The Cast Aluminum is a lot lighter than the steel rims I am running right now.
The bolt pattern is 4/137 on both Kawi and CanAm so I know they will bolt up. Has anyone tried this? Are there any negive issues I should be aware of before I pick up a set.
So far, this has been the cheapest option I have found.
Any input on this topic is welcome.
2010 Teryx LE,
Muzzy's Duel Exhaust
Dalton Clutch Kit
HW Overdrive Clutch Cover
Snorkeled
K&N Modded Air Filter
HID Light bar
Odyssey PC925 Battery
Black Rhino gauge Pod (Tach, volt, W Temp)
27" Zilla's
Muzzy 840, Stage II cams, 38mm throttle bodies,
324 injectors, Water impeller,
new stock crank, rods and barring
jfilion is offline
post #2 of 5 (permalink) Old 03-17-2011, 01:23 PM
Make sure the bolt holes are big enough. The teryx need 2mm bigger than most of the other brands with the same bolt pattern. You can drill them out though.
post #3 of 5 (permalink) Old 03-17-2011, 02:21 PM
The teryx has a 12mm stud, most others use 10mm.
Tearinitup is offline
post #4 of 5 (permalink) Old 03-17-2011, 09:25 PM
4x4pac's Avatar
Just because they have the same bolt pattern doesnt mean they will work. In 09 the teryx has a bigger hub. A lot of people bought after marked rims and found they would not fit the larger hubs. I doubt a cam am rim has as big a center hole as the teryx rims.
2009 Teryx LE FI
REAL OFF ROAD RIDERS DON'T RIDE WITH FLEAS
4x4pac is offline
post #5 of 5 (permalink) Old 03-19-2011, 07:39 AM
They will work just fine. My buddy has a can-am and his dad has a Teryx and they have been swapping tires back in froth for a little over a year now and has no problems. The only thing that they had to do was drill the can-am rims out just a little bit. Just make sure that the lug nuts are at german specs, goodintaught.
nnadenoff is offline
What size rims POWERTRIP Kawasaki Teryx Suspension Discussions 2 12-22-2010 01:32 AM
WTB Stock Rims ABoothe Want Ads 3 05-11-2010 09:01 AM
WTB Rims roaddog Want Ads 2 02-05-2010 08:12 PM
itp rims rhinokiller Kawasaki Teryx Exterior Discussions 8 07-11-2009 09:02 AM
Beadlock Rims???? Desertdog615 Kawasaki Teryx General Discussions 19 05-31-2009 10:07 PM
