Valve adjustment - Kawasaki Teryx Forums: Kawasaki UTV Teryx Forum
post #1 of 16 (permalink) Old 08-24-2011, 05:42 PM Thread Starter
ELKSLAYER's Avatar
Valve adjustment
What is up with this 08? I have to adjust the valves every 3 to 4 mo.
[SIGPIC][/SIGPIC]2008 CAMO NRA TERYX WITH RIPSAW TIRES, CAGE LOWERED 3".
Tow rig is a 98 DODGE 12 VALVE, QUADCAB, 4 DOOR, 4X4,SWB
Lumpdog trany,no plate, 4K GSK, Glow Shift Guages. KDP retained.2 1/2 Leveling Kit, 16* timeing, ,boost elbow,straight pipe,twin 5''stacks,35'' MT'S,BHAF And more
ELKSLAYER is offline
post #2 of 16 (permalink) Old 08-24-2011, 08:18 PM
pit dog's Avatar
Weak valve springs is the prob on all years,VFJ has them on sale.
pit dog is offline
post #3 of 16 (permalink) Old 08-24-2011, 11:49 PM
You're going to need valves too. Several reasons cause this, dirt, needing to adjust them sooner, crappy valves, running lean which causes the valves to get very hot and weak valve springs.
Most likely it is just the intakes, last two engines I built both had the intake valves sucked up in the head.
Good valves are pricy and good springs range from $110 to $250
You might want to have the valve seats recut to make sure they are good to go.
If you like call me and I will explain any of this.
601-771-0070
post #4 of 16 (permalink) Old 08-25-2011, 01:13 PM
pit dog's Avatar
good double springs are 100 from four stroke tech and mickey gives a 10 discount for forum members. V force john sale I thank was even cheaper.Most likely you valves are fine. Tore mine down for a 840 1400 miles valves looked like new,don't even leak a drop
pit dog is offline
post #5 of 16 (permalink) Old 08-25-2011, 06:23 PM Thread Starter
ELKSLAYER's Avatar
I had them done at 1000 miles and now it has 1400 on it. This is BS.
post #6 of 16 (permalink) Old 08-25-2011, 11:41 PM
No way the valves are still good if you are having to adjust them that often.
Common sense says if the are getting tight then they are moving closer to the rocker arm, how is that possible? Cause they are deforming and getting sucked up into the head.
You need new valves and springs too.
post #7 of 16 (permalink) Old 08-26-2011, 12:30 AM
Is detonation an issue with these engines?
I've seen many beat the seats so badly (detonating, or springs with not enough seat pressure) that the valve lash wouldnt stay set.
Wear, or improper geometry can do that, as well.
n2xlr8n is offline
post #8 of 16 (permalink) Old 08-26-2011, 07:13 AM
Detonation is not usually a issue with these engines.
What ever is causing it, when it happens best to just buy good valves and springs, re-cut the seats and be done with it.
post #9 of 16 (permalink) Old 08-26-2011, 08:28 AM Thread Starter
ELKSLAYER's Avatar
What is the problem that this is going on at such low miles?
post #10 of 16 (permalink) Old 08-26-2011, 09:39 AM
I thought atv type motors are to have the valves adjusted at 10 hours then around every 100 hours afterwards. I'm adjusting my oldest 750 motor for the first time at 1,050 miles, as it is now only starting if its choked.
I know the big logging company around my home town adjusts the valves on all thier 4 stroke quads once a year and they have sold machines to the public that are running well after 20 years. These machines get used almost daily, and although maintained, are often riden hard and put away wet.
valve adjustment robowelder Kawasaki Teryx General Discussions 21 10-02-2011 09:49 AM
Valve adjustment ELKSLAYER Kawasaki Teryx General Discussions 6 05-11-2011 10:41 AM
Valve adjustment help please eez Kawasaki Teryx General Discussions 3 03-18-2011 07:49 AM
valve help worken teryx Kawasaki Teryx General Discussions 3 09-12-2010 10:31 PM
Valve Job jta Kawasaki Teryx Performance Discussions 4 05-18-2010 05:37 AM
