Providing that you installed everyting back correctly, I'm going to guess that the belt is to tight. Check the belt deflection and make sure it is adjusted properly. Did you install a factory belt or different brand, I'm guessing factory if you got it from Todd cause he should know better than to use a aftermarket belt.
