fuel problems? - Kawasaki Teryx Forums: Kawasaki UTV Teryx Forum
LinkBack Thread Tools
Old 04-22-2012, 10:38 AM Thread Starter
fuel problems?
i need some help on an issue i have... i started out having a clogged up fuel pump i took it apart replaced the strainer on the bottom of the pump and cleaned the pump and all the parts.. i put it all back together and tested the volume i am gettin 1.7 ounces every time i turn the key on as the shop manual says i should but i dont have any way to test the pressure... i hook it back to the throttle bodies and get very inconsitant spray from the injectors i took them all apart and cleaned the injectors and reassembled the spray looked strong to me but still inconsitant will not start on its own if i give it a shot of ether it will start and die as soon as it burns the ether up and wont run on its own fuel i am stumped i dont know where to go from here im not getting a fi light
taderhead is offline
Old 04-22-2012, 10:53 AM
Did crud get down the line past the fuel pump?
Old 04-22-2012, 01:07 PM Thread Starter
im not really sure i cleaned the pump and all parts of the pump unit and cleaned the injectors and the fuel rails
Old 04-25-2012, 09:34 PM
09 fuel pump
mine did the same thing added a o ring to fuel pump connector where they snapped together 559 707 4420
haydaddy is offline
Old 07-30-2012, 11:09 AM
I have a 2008 Teryx and am having the same problem the fuel filter is new the carbs were just re jeted by a kawi dealer and the shop man tells me the fuel pumps are known to crap out. I ordered a new one to see if that solves the problem. Seems like the fuel just trickles into the filter a drop at the time and the filter never gets more than 1/4 full.
freytes2004 is offline
Old 07-31-2012, 09:16 PM
You can either get a fuel pressure gauge or trouble shoot with a $500 pump. The question is, is it holding pressure under load?
Problems with fan. atv4fun Kawasaki Teryx Electrical Discussions 6 07-19-2010 01:01 AM
Any problems with the unifilters? jaketruck Kawasaki Teryx Performance Discussions 8 06-08-2010 03:55 PM
Flooding problems! Please help my 08!! Hnryzuniga Kawasaki Teryx General Discussions 14 05-13-2010 02:29 PM
Dynojet problems?? Fletch-c Kawasaki Teryx Performance Discussions 35 05-25-2009 03:12 PM
New and already have problems Lhall Member Introductions 7 08-25-2008 09:39 AM
