4 x 4 - Kawasaki Teryx Forums: Kawasaki UTV Teryx Forum
post #1 of 5 (permalink) Old 03-25-2013, 08:30 PM Thread Starter
jfilion's Avatar
4 x 4
Not sure if anyone uses this forum anymore. But I though it was worth a try.
Anyone have trouble with their 4wd not engaging?
I've got a 2010 T2. When I hit the switch the light doesn't come on and there's no engagement of the front tires.
I haven't done any trouble shooting yet. Just wondering if there's a common problem.
2010 Teryx LE,
Muzzy's Duel Exhaust
Dalton Clutch Kit
HW Overdrive Clutch Cover
Snorkeled
K&N Modded Air Filter
HID Light bar
Odyssey PC925 Battery
Black Rhino gauge Pod (Tach, volt, W Temp)
27" Zilla's
Muzzy 840, Stage II cams, 38mm throttle bodies,
324 injectors, Water impeller,
new stock crank, rods and barring
jfilion is offline
post #2 of 5 (permalink) Old 03-28-2013, 08:48 AM
glockman55's Avatar
Quoted: 2 Post(s)
I never get a reply on here either.. not in the loop I guess.. I have had this same issue with my 09.. but usually in very cold temps.. after setting inside it starts working again.. I think it's a vacuum switch that moves a cable to engage and dis-engage.. could be just an iced up problem..
glockman55 is offline
post #3 of 5 (permalink) Old 04-02-2013, 11:27 AM
i had this problem, put some lube on the cable on the right had side of the front diff, seemed to work a little better also when i had the machine apart the vaccum to the cable is located under the passengers seat put some lube on it so it runs down into the cable, and when its cold it can be a bear, if you turn the engine off you can manualy put it into our out of 4x4
hang1p is offline
post #4 of 5 (permalink) Old 04-11-2013, 10:04 AM
my 2012 has never had a problem shifting into 4 wheel drive even in cold weather. I have noticed that it will only engage at lower speeds and if you are going fast you must slow down to get it to engage. the owners manual say you need to be stopped, yet the commercial says shift on the fly.
dave03 is offline
post #5 of 5 (permalink) Old 04-12-2013, 06:36 PM
X2...used some WD-40 on linkage on right side of front diff and worked it back and forth (assisted by had) until completely free.
b0rderlinecrzy is offline
