08 Teryx- loss of power- please help - Kawasaki Teryx Forums: Kawasaki UTV Teryx Forum
post #1 of 4 (permalink) Old 05-08-2013, 06:34 AM Thread Starter
I am working on a 2008 Teryx 750. My friend said it would only go approx., 30 mph, and it only has 100 hrs on it. I test rode it and sure enough,,,,, 30 mph! I have checked the valve clearance, cleaned the carbs, sync'ed and adjusted idle mixture, removed the exhaust, checked the air filter and fuel filter, fuel vent, vacuum lines.... I checked to make sure the vacuum pistons in both carbs are functioning properly and I even checked to make sure the pedal/ throttle cable is opening the butterfly's fully. I do not have a tachometer to check top RPM in neutral but I have held the throttle wide open and the engine rev's to a fairly high rpm and runs smooth when held at full throttle. Shouldn't they have a rev limiter??? I would assume if held wide open they should reach high RPM and cut out or miss and NOT run smoothly... Any help on this machine would be greatly appreciated!!!! Just about at my wits end.......
sbaters is offline
post #2 of 4 (permalink) Old 05-09-2013, 02:34 AM
I assume you are in high gear? Is it a stock cdi box?
post #3 of 4 (permalink) Old 05-24-2013, 08:28 PM
rod
Smile
went through the same thing, check your spa
rod is offline
post #4 of 4 (permalink) Old 05-24-2013, 08:55 PM
Check the belt deflection, sounds like a way worn out belt or dirty clutches.
Tags
please help, teryx no power
Loss of speed and power nate177 Kawasaki Teryx General Discussions 22 01-15-2013 01:49 AM
Power Loss when warm AfghanTeryx Kawasaki Teryx Performance Discussions 10 08-05-2011 01:03 AM
help loss of power kaptn12 Kawasaki Teryx Performance Discussions 15 05-19-2011 10:41 PM
08 Teryx LE power loss jeryx Kawasaki Teryx General Discussions 0 11-15-2009 03:58 PM
Teryx Power Loss rodleague Kawasaki Teryx General Discussions 5 09-10-2009 07:55 AM
