DASARACING MSD testing and more - Kawasaki Teryx Forums: Kawasaki UTV Teryx Forum
post #1 of 22 (permalink) Old 01-16-2010, 03:41 PM Thread Starter
FUELATV and i went out to dos some baseline testing today. We setup cones and did some timed runs and checked top speeds. We did three runs for each test then took the average. All speeds are speedo speeds. Here is what we found today.
STOCK 2010 Teryx
51 MPH top speed ......... 7200 RPM
200ft time - 37 MPH @ 6.10 sec
400ft times - 45 MPH @ 9.62 sec
700ft times - 49 MPH @ 14.39 sec
added MSD on advance map 3 and fuel map 4
58 MPH top speed ....... 8300 RPM
200ft time - 38 MPH @ 6.02 sec
400ft times - 46 MPH @ 9.51 sec
700ft times - 51 MPH @ 14.20 sec
added DASARACING over drive clutch cover
60 MPH ........ 7400 RPM ....... all 200,400 and 700 ft times were the same as above.
Here is the big issue ....... YES ... the over drive cover only gained 2mph on top end ...... BUT ... it dropped the max RPM by 1000 and still went faster. Without the overdrive cover the stock car is REVING OUT BIG TIME at 58MPH and at 8300 RPM. With the over drive cover installed it is crusing at 60 and not reving out hard at 7400 RPM. You wont want to drive your teryx around at 58MPH spinning 8300 RPM for very long. By adding the over drive cover you will gain 2 MPH and drop the RPM's down to 7400. Once we add pipes, intake and throttle bodies this car will rev out higher then the 7400 and gain some more top speed. Our 840's with the same setups are hitting 70+ MPH. More testing to come very soon. ......... all other clutch parts were STOCK.
post #2 of 22 (permalink) Old 01-16-2010, 03:51 PM
Good info Steve
How did you have timing on one map and fuel on another?
post #3 of 22 (permalink) Old 01-16-2010, 05:05 PM Thread Starter
Originally Posted by Hunterworks View Post
Good info Steve
copy and paste .....
post #4 of 22 (permalink) Old 01-16-2010, 06:03 PM
Originally Posted by DASARACING View Post
So you meant timing curve off of three pasted on four?
What you typed says you had the timing on curve three and the fuel on curve four.
Just trying to figure out, thought you might have found something out I should know.
post #5 of 22 (permalink) Old 01-16-2010, 07:32 PM
That is correct.
Since map three cannot be adjusted I copied the timing advance from the stock MSD map three and paste it into the timing advance on map 4. This is what we felt would be the best combo since we could only adjust the rev limit and MPH limit on map 4 or higher and not map 3.
Hunterworks, keep in mind when you load a new map you are actually loading it for all tunes not just the tune you are on. The copy and paste buttons become very usefull when building multiple maps into one MSD unit. The wording MSD is using in the operation guide is a little disceaving.
FUELATV is offline
post #6 of 22 (permalink) Old 01-16-2010, 08:02 PM
Well aware of this, was just thinking you guys figured out a way to use the timing in one curve and fuel in another.
Thanks for clearing it up.
FuelATV, you better post up from now on, Steve confuses me and that is easy to do!!
post #7 of 22 (permalink) Old 01-16-2010, 08:15 PM Thread Starter
Well aware of this, was just thinking you guys figured out a way to use the timing in one curve and fuel in another.!!
WE DID ........ COPY AND PASTE ...... When i was looking at all of the ignition curves i liked the ignition curve on map 3 best.
The problem is that when i say map3 ignition curve alot of people have no clue what i am saying as it is labled advance on msd.
post #8 of 22 (permalink) Old 01-16-2010, 08:33 PM
Steve, I totally understand but the way you wrote it I thought you were saying you were using curve 3 timing and curve 4 fuel at the same time not taking curve three and pasting in curve four.
I thought you guys figured out a new way to use the software
post #9 of 22 (permalink) Old 01-17-2010, 09:26 AM Thread Starter
Our next test ww will run will be with dasa pipes installed ..........
post #10 of 22 (permalink) Old 01-17-2010, 10:06 AM
STOCK 2010 Teryx
I've said this in an earlier post spacing the clutch cover away from the spider(or using a clutch cap) does more than just top speed it also adds more gearing through the shifting phase... The reason it was revving so high is because it ran out of gearing through the clutch so all it can do then is over-rev for more top end.
