2 main jets? - Kawasaki Teryx Forums: Kawasaki UTV Teryx Forum
post #1 of 13 (permalink) Old 02-08-2010, 02:46 PM Thread Starter
2 main jets?
anyone have 2 kawasaki teryx keihen main jets/?i need a 205 and a 210.i also have some smaller jets that maybe we can trade if needed..but pm me if you have them.
post #2 of 13 (permalink) Old 02-08-2010, 03:57 PM
WOW! cant believe your going that big, what are you at 20,000 feet! I have Keihin 165 in front and Keihin 168 in back, I'm at 800 feet. I'll take a look around and see if I got any...maybe? Are you using a A/F meter?
post #3 of 13 (permalink) Old 02-08-2010, 04:29 PM Thread Starter
i ride at 600 ft to 3000 ft elevation and i have 6 -1 inch holes in the airbox.i have a 195 and 200 in it now and seems to run like a bat out of hell...but the plugs are kinda white...so i figured it was lean.i have the 840/dyna cdi /muzzypro..maybe i dont need them...but the plugs sure look lean to me.maybe im wrong.maybe someone could give me some pointers on checking the plugs to make sure im doing it right.
post #4 of 13 (permalink) Old 02-08-2010, 07:38 PM
Wildcat's Avatar
Man Im not a pro but I think with out having a full sweep A/F gauge I think you're just treading water. I guess you could get it close from the spark plugs. Good luck in whatever you do bro.
2009 FST 840, Stage 3 cams, MSD, DASA 38mm TB's, DASA Intake, Hand Port and Polished, +1 valves, Muzzy Pro, Dalton, XMF custom 2 seater, bed delete, Twisted Stitch Seats....TBC.
Wildcat is offline
post #5 of 13 (permalink) Old 02-08-2010, 08:13 PM
Wildcat's Avatar
Sign up and ask away.......
08 with a open box - Kawasaki Teryx Forum
Wildcat is offline
post #6 of 13 (permalink) Old 02-08-2010, 09:55 PM
To begin with you can't read plugs on these bikes because you can't run the motor at a specific rpm and shut it off... The CVT will always cause the motor to wind down.
If the bike runs like a bat out of hell leave it alone... these bikes don't run well at all lean, not lean enough to hurt anything.
post #7 of 13 (permalink) Old 02-09-2010, 12:08 AM
Exactly...and I'm not sure they even make a 205...I think you have to start drilling them out at that point...
post #8 of 13 (permalink) Old 02-09-2010, 07:25 AM
Keihin does make 205 and 210.
Sorry I've never been good at reading plugs, too many variables and I think you would have to install new ones for every run to even be close to reading them.
I also disagree that these can't be run to lean to damage anything, a lean motor will run like a motherfkr....for a short period of time.
Whitey..check your pm's, sent ya a message about my meter.
post #9 of 13 (permalink) Old 02-09-2010, 07:43 AM
Banned
With the unleaded gas we have now it is sometimes hard to get a light tan color on the plug. Toget a good reading on the plug you need used plugs with a carbon build up.Run it around for 15-20 min.,then run it wide open down the road and hold it there for 5 to 10 seconds and turn the key off. When you pull the plug look for the line where the carbon is blown off on the ground strap. The line should be in the middle of the bend of ground strap. If it is up closer to the end,or tip of the strap,it's rich. If it has burned down around the bend towards the threads of the plug,it's lean. It don't mater if it's a two stroke or a lawnmower this will work for the main jet reading.
I have jets clear up to 250's if needed.
Four Stroke Tech is offline
post #10 of 13 (permalink) Old 02-09-2010, 10:50 AM
This is false... A two stroke will run great lean but will of course have a melt down and thats where all these horror stories come from. To be expected of a two stroke. These bikes don't run well at all lean and damn sure don't make any power if you're running it to lean to hurt something.
Look at it this way... Out of all these people doing their own jetting for the first time and never heard of anyone having a melt down. You think its because everyone is that good or everyone is that lucky? These are 4-stroke motors man... Given with power adders you have to be more cautious but N/A good luck.
need jets? whitey Kawasaki Teryx Performance Discussions 0 01-18-2010 11:44 AM
main output shaft mossman81 Kawasaki Teryx General Discussions 0 09-17-2009 10:38 PM
jets pro4 Kawasaki Teryx Performance Discussions 1 01-10-2009 04:55 AM
rear main seal part number? puddle jumper Kawasaki Teryx General Discussions 1 08-19-2008 06:51 AM
Why are there two different main jets? Hunterworks Kawasaki Teryx Performance Discussions 5 06-09-2008 08:42 PM
