840 results with dalton kit... - Kawasaki Teryx Forums: Kawasaki UTV Teryx Forum
post #1 of 22 (permalink) Old 04-04-2010, 09:30 AM Thread Starter
i got my clutch kit installed yesterday..i used empty weights with no screws and rivots..amber or orange primary spring with silver secondary spring.and a utv crap milled stock cover..i bought this kit and cover from a dude on teryx forums for 200.00 and couldnt turn it down.anyways here is the report..it has a little stall than stock...but i kinda like that!and i also removed the kebs by removing the arm.now for the ride report...it is very important to get this done!it will spin the tires so hard it feels like an old kx 500 it spins so hard!i think i can do a donut on dry blacktop!it will spin so easy now and pulls like a freight train now..but i am kinda dissapoited in my top speed run with stock wheels and tires....its only 68 and its hitting the rev limiter....thats from the stock speedo.but man its a blast to ride now..i am so satisfied with it now...it runs killer.now i got to fine tune the carbs and be done with it for a while anyways.its time to ride!anyways my outlook on the dalton stuff is 2 thumbs up.
post #2 of 22 (permalink) Old 04-04-2010, 10:09 AM
Whitey what kind of ignition are you running and what kind of rpm is it when you hit rev limiter, sounds like you need to adjust your rev limiter is your ignition programable, I am running a msd from Hunterworks with my rpm limit set at 91 or 9200 when I finish my AMR 840 I will have to get the msd reprogramed
post #3 of 22 (permalink) Old 04-04-2010, 10:52 AM Thread Starter
i have a non programmable dynatek...im not sure what rpm it is.
post #4 of 22 (permalink) Old 04-04-2010, 01:06 PM
Originally Posted by whitey View Post
now for the ride report...it is very important to get this done!it will spin the tires so hard it feels like an old kx 500 it spins so hard!i think i can do a donut on dry blacktop!it will spin so easy now and pulls like a freight train 2 thumbs up.
post #5 of 22 (permalink) Old 04-04-2010, 08:20 PM
It is 9200 rpm,
post #6 of 22 (permalink) Old 04-04-2010, 09:35 PM
No way that car is hitting 9200 RPM at 68 mph....... SOMTING WONG
post #7 of 22 (permalink) Old 04-04-2010, 09:51 PM
With just a clutch cap that's very believable.
Mine with no clutch kit rev limits at 72mph with a fresh belt... Worn belt this could be lower... If you have it clutched to shift at a higher RPM through the shifting phase the top speed will be lower. If you want more top speed you'll have to put more weight in the clutch weights to get the shift rpm down but this also might make you slower through the shifting phase depending on what RPM the cam likes.
post #8 of 22 (permalink) Old 04-05-2010, 06:02 AM Thread Starter
i also added a new belt when i done the install.before the kit with the stock clutching and 840 i could get to 60 fast and then it would cut out on the rev limiter.same symptom then as i am having now with the clutch kit and cap except its at a higher mph.i was hoping for more but it does get there fast.
post #9 of 22 (permalink) Old 04-05-2010, 08:29 AM
pit dog's Avatar
There you have it////dalton. Spanked by gringed clutch again.Had to take my pro's off to take to shop.stock moter hw air filter mod,msd vfj clucth 63 mph on speedo.73 mph with pro's lol just jabbing you back whitey.seriously good luck.
pit dog is offline
post #10 of 22 (permalink) Old 04-05-2010, 09:25 AM Thread Starter
here is a thought that came to mind about the cover.....me and my mechanic compared the 2 covers i had while i had it apart and couldnt find no differences what so ever.it looks exactly the same but i installed the one i had bought because he told me it was an utv crap cover and would help top end.is there any chance that my car could have gained top speed with the clutch kit and new belt while using the stock cover??would a dalton cover give me anymore?
HW results from Fundy Std. Bore Kit Hunterworks Kawasaki Teryx Performance Discussions 58 10-07-2009 01:12 AM
King of the Hammers SxS results (so far) loco UTV Desert Racing 1 02-25-2009 01:29 PM
HW Muzzy Test Results!! Hunterworks Kawasaki Teryx Performance Discussions 19 09-15-2008 06:44 PM
