Front carb over 16 on air fuel gauge - Kawasaki Teryx Forums: Kawasaki UTV Teryx Forum
post #1 of 7 (permalink) Old 04-25-2010, 03:51 PM Thread Starter
N2 Teryx's Avatar
I have an 08 teryx with Muzzy exaust, Hunterworks Carb kit with tpi valves and a cdi Set on hunterworks program. I set the carbs up 2nd clip 146 front 148 rear drilled holes and bought a air/fuel gauge the rea bung on the muzzy is around 12.5 the front bung goes straight to 16 and I guess thats as high as it goes.
I replaced the main jet with a 142 to see if it would make a difference. It didnt The air screw has no effect. Any thoughts
N2 Teryx is offline
post #2 of 7 (permalink) Old 04-25-2010, 04:09 PM
Got a air leak somewhere I would think. Are carbs tight and down in rubber?
Also, where is it that high at?
post #3 of 7 (permalink) Old 04-25-2010, 04:29 PM Thread Starter
N2 Teryx's Avatar
I will double check but thought it was on good.
Is 16 to much air or fuel
N2 Teryx is offline
post #4 of 7 (permalink) Old 04-25-2010, 04:30 PM Thread Starter
N2 Teryx's Avatar
at the bung right at the front carb the back carb seems ok
N2 Teryx is offline
post #5 of 7 (permalink) Old 04-25-2010, 04:39 PM
16 is way high or way lean, either it is getting too much air from somewhere or not enough fuel for some reason other than the jet being too small, that is not it.
post #6 of 7 (permalink) Old 04-25-2010, 05:57 PM
Check the slide diaphragms, I have had 3 of them fail and when they fail that cylinder goes lean.
'08 Red LE, Hunterworks Carb Kit & TPI Valves, Dynatech CDI (Hunterworks Tune), Rockstar Motorsports Cage&Mirror, JetTrim Seats, Dalton Clutch Kit, Muzzy Exhaust, Muzzy cooling fan, K&N filter + outerwear, BFG KO Radials, ITP Beadlocks, HCR 6" LT kit... and I'm just getting started
teryxpilot is offline
post #7 of 7 (permalink) Old 04-25-2010, 08:03 PM
Yeah that can happen, maybe the diaphragm is not in right so the slide is not working right.
Take plenum off and rev it up, see if both slides are opening.
air/fuel gauge jaketruck Kawasaki Teryx Performance Discussions 2 08-17-2009 05:57 AM
Fuel, Temp & Volt Gauge Kits from BRP BRP Kawasaki Teryx Electrical Discussions 6 04-23-2009 09:18 AM
Pics of Fuel/Air Ratio gauge header sensor weld on bungs and plugs Magellan Kawasaki Teryx Performance Discussions 24 12-09-2008 04:48 PM
Available Fuel Gauge Options dieselpowered Kawasaki Teryx General Discussions 44 06-24-2008 04:52 AM
Fuel Gauge dieselpowered Kawasaki Teryx General Discussions 9 03-04-2008 11:44 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67
