more 840 tuning...? - Kawasaki Teryx Forums: Kawasaki UTV Teryx Forum
post #1 of 21 (permalink) Old 05-25-2010, 04:13 PM Thread Starter
more 840 tuning...?
on my rear cylinder.....i figured i would put the air fuel guage on it again since its warmed up here....at idle....its around 12 and just barely off idle its goes to 17 to 19 and then with just a smidge more fuel...just barely enough to hear the differance in the exhaust it clears up and is running 12 and 13...and then onto wide open up to 70 mph its running a steady 10.8...i have a stock needle with a 205 main ...should i bump the air screw in one turn and drop the main down to 195 or what...i have a 205 main in there right now/i dread removing the sub box to retune the front piston...im going to get the rear first..any tips is highly appreciated.
post #2 of 21 (permalink) Old 05-25-2010, 04:30 PM
Whitey that is about what I would try first , except I would leave the screw alone and then see what the gauge says. I bet it will be real close. Good luck.
post #3 of 21 (permalink) Old 05-25-2010, 04:38 PM Thread Starter
i was going to bump the screw because off the lean area or should i just leave it alone/
post #4 of 21 (permalink) Old 05-25-2010, 06:10 PM Thread Starter
well after a 195 main and a 40 pilot and 1 shim under stock needle....the rear cylinder is going crazy.....11.5 at idle and going to 19 and 20 and sometimes higher while running wide open....i added more fuel and it gets leaner....any ideas...i can run for a 1/4 mile at wide open and it will never get steady....it will sit at 11 and 12 for a minute and then go crazy....up to 20 some....it runs good and sounds good but the air fuel guage goes crazy....any ideas
post #5 of 21 (permalink) Old 05-25-2010, 06:11 PM Thread Starter
and it seems to backfire more thru the exhaust on letting off the gas....the guage gets so eratic it will frezze up on my lm1 and i will have to reboot it.
post #6 of 21 (permalink) Old 05-25-2010, 06:13 PM Thread Starter
and while in neatral my idle is fine but it all goes lean after revving it up ...
post #7 of 21 (permalink) Old 05-25-2010, 07:00 PM
Whitey , put the shim back so you have two. If you went with the 40 only go out 1 1/2 turns at first. You did not add fuel if you dropped the needle and dropped the main .. you just leaned it out way to much.. You are also changing way to many things at once. If you were running 205 then go with a 200 main put the shim back in and while your at it put the 38 back to. Turn your screw out 2 3/4 turns then check. I would almost bet it will be right
post #8 of 21 (permalink) Old 05-25-2010, 07:11 PM Thread Starter
no i have changed one at a time but only reported to you guys time to time...anyways when i started i was way rich at wide open...i backed down to a 195 from 205...i have the 200 in the front.after that i was going way lean everywhere...so i added a shim under the needle to raise it...[rasing the needle means to richen right]and then i checked it and it didnt hardly see a differance...so then i added the 40 pilot..anyways after the last report and it was eractic ..i drink a half a beer for good timing and thinking!!and tried it again and it run steady at 12s and low 13s..it got dark and i quit fooling with it...and after all this time that odd sounding miss that has drove me crazy...it seemed to be a whole lot better..not gone...but better..
post #9 of 21 (permalink) Old 05-25-2010, 07:29 PM
Ok , I thought you did that all at once.If you add a shim it does richen it up low to mid the main affects everything a little . That is why they say to get wide open right first then mid , idle.. Of course you know that if you go up mains then your richen it , down a size leanin it.. So , if you get it mid to upper 12's and stay under 13.4 your
post #10 of 21 (permalink) Old 05-25-2010, 07:42 PM Thread Starter
well while im tuning it..all the front plastic off...the engine covers anyways...and everyone say its richens up after the plastic is back on.
dalton tuning help, looking for input dave_dj1 Kawasaki Teryx Performance Discussions 17 03-12-2010 12:42 AM
Almost a full report on 840 tuning............ Four Stroke Tech Kawasaki Teryx Performance Discussions 63 01-27-2010 09:42 PM
Dalton clutch tuning BRET901 Kawasaki Teryx Performance Discussions 14 01-05-2009 02:22 PM
Self Tuning EFI coming!!! Hunterworks Kawasaki Teryx Performance Discussions 4 12-08-2008 06:17 PM
67MPH and still tuning [email protected] Kawasaki Teryx Performance Discussions 9 05-30-2008 04:28 PM
