Whisper MAP needed - Kawasaki Teryx Forums: Kawasaki UTV Teryx Forum
post #1 of 9 (permalink) Old 05-30-2010, 12:21 PM Thread Starter
brettrown's Avatar
Whisper MAP needed
Does anyone have a MSD map for std Muzzy w/ whisper cores. I could really use one. I'm running at around 11.5 though out the throttle range.
brettrown is offline
post #2 of 9 (permalink) Old 05-30-2010, 02:07 PM
I would check with Todd at Hunterworks or Steve at Dasa
post #3 of 9 (permalink) Old 05-31-2010, 12:48 AM
I would go in and take about 5 to 10% from all blocks in map if it is running 11.5 in all areas then recheck it
post #4 of 9 (permalink) Old 05-31-2010, 09:01 AM Thread Starter
brettrown's Avatar
So if the block says 0 right now, I would put a -5 to -10?. Todd do you have any Updated Maps, that are little leaner then your # 5.
post #5 of 9 (permalink) Old 05-31-2010, 10:05 AM
You actually should watch your air/fuel as you drive and look where the colored dot is on the screen in the MSD software as you drive and when the air/fuel drops below or above 12.5 to 13.2 then make the adjustment by changing the number. The change is made as soon as the number is changed no transfer needed
If the box has zero in it and you need leaner then you put a negative number in it.
I usually jump in increments of 5% then make more fine tuned adjustments as needed.
post #6 of 9 (permalink) Old 05-31-2010, 11:50 AM
How much difference in performance does it make when you go from 11.5 to 12.5 or so? I know we all bash our brains trying to get these PERFECT but I was jut wondering how much it really matters. I'm tuning my 840 still....to this day it aint perfect.
08 Teryx 840 stage III, dalton, dynatek, 48" bed delete", pds k2 cage, fusion head unit, alpine amp, fosgate 8" marine, kicker 10" sub.
post #7 of 9 (permalink) Old 05-31-2010, 03:45 PM
The dyno might know the difference but your butt won't notice most likely.
The place you may notice it is leaner is faster on top end but don't want to go over 13.2 or so
post #8 of 9 (permalink) Old 05-31-2010, 11:09 PM Thread Starter
brettrown's Avatar
Thank you. I actually did 3% less across the board on your MAP 5. Pretty close. I'm going to have to drive and tune a little more. How/ do you need to adjust the MAP for both cylinders?
post #9 of 9 (permalink) Old 06-01-2010, 06:48 AM
You put the bung in front cylinder and tune the engine off that one then move it to the rear and if it needs a across the board change you go to settings where you change RPM and speed limter and there is a setting for cylinder trim in percent
whisper core with 840 whitey Kawasaki Teryx Performance Discussions 3 02-12-2010 12:37 PM
Muzzy Whisper Cores Teee-rible Kawasaki Teryx's & Teryx Parts For Sale 9 08-14-2009 12:22 AM
HW Tested Muzzy Whisper Core Hunterworks Kawasaki Teryx Performance Discussions 22 07-04-2009 06:28 PM
Muzzy whisper cores on site Hunterworks Kawasaki Teryx Performance Discussions 4 06-14-2009 10:06 AM
Muzzy Whisper Core WHEN???? Teee-rible Kawasaki Teryx General Discussions 20 06-10-2009 04:35 PM
