Loud clunking noise? - Kawasaki Teryx Forums: Kawasaki UTV Teryx Forum
post #1 of 14 (permalink) Old 06-14-2010, 08:20 PM Thread Starter
Just installed a Dalton clutch kit, muzzy, MSD, and Hunterworks billit OD w/bearing on a new 09 sport Sat. I still can't believe the difference it has made. It runs great in high but when I have it in low and start down a hill or stomp on it and let off it makes a loud clunking noise or rattling noise. Sounds like it is falling apart. It doesn't do this in high. Is the belt slipping or is it something else? I don't use low much but it didn't do this before. Any help is greatly appreciated.
bandit0278 is offline
post #2 of 14 (permalink) Old 06-14-2010, 08:55 PM
Well, all the parts you bought work the same no matter what it is in, so the common denominator is the low gear. I would point to something wrong with that
post #3 of 14 (permalink) Old 06-15-2010, 06:35 AM
My Bone Stock 08 does the same thing, sounds like its under the bed, I have looked it over and over and over and cant find what it is. sounds like a drive shaft or u joint,(but it's tight) only does it when you let off the gas going down a slope in low gear. when you find it please let us know. Allan
ABoothe is offline
post #4 of 14 (permalink) Old 06-15-2010, 06:41 AM
Had same issue when mine was stock. It is just the play from the machine turning the drive train from trying to twist it from foward to reverse. Just the nature of the beast in my machine. But since you seemed to only notice this since you did all of that work, satisfy yourself and make sure all is right. I have done all of those mods as well.
post #5 of 14 (permalink) Old 06-15-2010, 08:41 AM
Any chance it is the KEBC - brake control? Maybe just unplug it and try driving to see if it goes away. I believe it only is active from 5 mph and less. Just a guess, mine makes lots of noises also but nothing found bad yet???
post #6 of 14 (permalink) Old 06-15-2010, 07:37 PM Thread Starter
Thanks guys for the input. I am glad I'm not the only one. Going to do some searching this weekend to see if I can find anything. Let you all know.
post #7 of 14 (permalink) Old 06-16-2010, 08:55 PM Thread Starter
Figured it out
After researching some of the other forums l found that the gear linkage may need adjusting. Once I got the plastic off only took about five minutes to adjust. I guess somehow it had moved, but still can't figure out how it did. Anyways I just loosened the two nuts and turned the linkage rod to tighten up the distance between the two, tightened the nuts back and took it for a test spin. Defintely fixed the loud clunking sound when I let off the gas in low. Thanks to everyone for the advise, hope this helps someone else.
post #8 of 14 (permalink) Old 06-16-2010, 10:45 PM
Flyin's Avatar
Hi all
I had the same problem the clunk noise the 1/4" shift rod has a lot of flex in it and I welded a 1/2" square tube in between the threads which greatly reduced the flex. Adjusted the shift linkage which reduced noise from the gear lash.
Good luck.
Flyin is offline
post #9 of 14 (permalink) Old 08-04-2011, 11:09 AM
Angry Clunking noise
I have a2008 teryx and when I put it into low and barely take off it makes a clanking noise. I have put a cdi on it but that's it. When I floor it in low it reacts normal and pulls hard but when I let of or go at a slow steady speed it makes a knocking/clanking sound does anyone know whats wrong
Jeckley is offline
post #10 of 14 (permalink) Old 08-04-2011, 11:16 AM
shifting linkage needs to be adjusted so that it will stay fully in low. Mine did the same thing and so has others.
Anyone know if the Pro Circuit Dual t-4 Exhaust is any good or too loud for a teryx? ichrisi88 Kawasaki Teryx Performance Discussions 0 04-19-2010 05:00 PM
Teryx Loud Shifting Noise?? Jon1981 Kawasaki Teryx General Discussions 6 03-04-2010 08:38 PM
2008 teryx transmission clunking!!!HELP!!! OIDALE Kawasaki Teryx General Discussions 4 02-25-2010 02:03 PM
New Noise dezrtrat Kawasaki Teryx General Discussions 11 12-01-2009 04:22 PM
Loud Pop in Low Gear slade11_98 Kawasaki Teryx General Discussions 1 08-05-2009 06:39 AM
