Overheating cured - Kawasaki Teryx Forums: Kawasaki UTV Teryx Forum
post #1 of 15 (permalink) Old 08-30-2010, 07:21 PM Thread Starter
Thumbs up Overheating cured
Rode Sat. and my bike stayed below 185 deg. . This was a big concern of mine because I had to try several combos before I could control the temp of my 840. I ended up with DASA's impellar , fan over ride switch, and engine ice. Also fattend up my lowend rpms to about 11.5. Man, I have to say before I broke my rear wheel off my bike it was amazing. I mean it was hitting HARD and would launch like a rocket.. Merlin & I were tearing up the trails... Also mixed racing fuel 110 octane leaded with 93 octane.. about a one to three ratio. My bike seemed to like it.
post #2 of 15 (permalink) Old 08-30-2010, 09:59 PM
Glad to hear it, I am gonna add the Dasa impeller to my 2010 just for good measure. Well with that 840 Im sure that wont be the last whel you break
efajeep is offline
post #3 of 15 (permalink) Old 08-31-2010, 12:43 AM
Good to hear you fixed the overheating issue. This is the combo I used. DASA impellar, custom rad and water. Will not go over 200deg no matter how hard I push it.
ID:	2623   Click image for larger version
post #4 of 15 (permalink) Old 08-31-2010, 06:29 AM
Why are you using the race fuel?
post #5 of 15 (permalink) Old 08-31-2010, 06:02 PM
merlin's Avatar
for the lead,it runs cooler,it burns cleaner,it burns faster,12.5 compression,advanced timing. all we have is reformulated unleaded and it sucks. i run pure race fuel with 2% nitro, ive put a ton of time and money in my machine,i change my engine oil after every ride and clean my air filter, a little overbored yea,but you will not see a engine fail on my machine unless i get carried away with NOS and then ill scatter it,i promise. why would anyone not run race fuel on a 840 and deff a std bore.please dont effin say cause it is pricey.
MERLIN MOTORSPORTS GROUP TERYX
merlin is offline
post #6 of 15 (permalink) Old 08-31-2010, 07:05 PM
I was thinking that it would run cooler and cleaner and on a 12.5 compression engine with the timing right should perform better but when I asked the other day I got mixed opinions. I am with Merlin on the pricey, I shot the crap out of the price issue long long ago and if I can benefit any from fuel I would not hesitate, I mean I have a 2006 Rhino that I put more miles on than I will my Teryx and it has 1200 miles on it, so the cost of my fuel will be a small % of the big picture and hey man when you smell race fuel it just makes you think fast.
post #7 of 15 (permalink) Old 08-31-2010, 07:29 PM
Actually it burns hotter, slower and dirtier. It has more octane therefore a larger molecule.
The whole point to run a higher octane fuel is to slow the burn down that was sped up by the higher compression pistons
post #8 of 15 (permalink) Old 08-31-2010, 07:33 PM Thread Starter
Not to mention the fuel in my tank was four months old and getting stale.. Also I mixed because of the above reasons and if you would actually check a 93 octane fuel out of the pump it would range from 88 to 92 octane.. By the time the fuel is refined ,shipped and stored its octane rating isnt true. All I know is my bike responded better... ran cooler.. and yes Big Daddy the boys behind us loved our vapors
post #9 of 15 (permalink) Old 08-31-2010, 07:56 PM Thread Starter
Oh, your right about that. But if your running say a true 12.5 to 1 ratio and your timing is advanced what should you do ?? Read my above post.. Stale fuel and all. I mixed so my octane was probably a true 93 to 96 octane. Have you seen what spark knock and predetenation does to a piston. I have seen people use higher octane fuel and NOT need it & guess what ? They Lost performance.. Trust me I didnt.. The fuel may not of contributed to my heat issue.. But I do know the combo I did made a huge diffrence in my temp. and my bike ran stronger than I ever remember it. Maybe just some good air thay day...
post #10 of 15 (permalink) Old 08-31-2010, 08:26 PM
KYWILDCATS,
I'm picking up Dasa's impellar also. How many quarts of ice do I need to refill the radiator? I'm planning on installing a fan override and I was wondering if you just made your own fan override switch and tapped into the factory fan or just purchased a kit. Thanks
ichrisi88 is offline
More help with overheating salmonteryx Kawasaki Teryx General Discussions 12 05-24-2010 04:59 PM
rear end overheating rons Kawasaki Teryx General Discussions 2 09-27-2009 03:11 PM
Overheating gomezj1988 Kawasaki Teryx General Discussions 2 09-20-2009 11:26 PM
Overheating Teryx cepennington Kawasaki Teryx General Discussions 23 03-17-2009 06:22 PM
overheating BeerGuzzler Kawasaki Teryx General Discussions 5 03-18-2008 08:48 PM
