Siphon Break - Kawasaki Teryx Forums: Kawasaki UTV Teryx Forum
post #1 of 20 (permalink) Old 10-18-2010, 06:46 AM Thread Starter
DamnBigPapa's Avatar
Siphon Break
So it seems that UTV Crap is the only vendor I can find that sells a pre-made siphon break. A couple questions ...
1) Why a standard bore and big bore kit? The Standard Bore seems smaller, but wouldn't it be better to just get the BBK break? Do they work the same, just a larger tank?
2) My 2009 already has an accumilator tank, so is it just that it's not sufficient. I was considering modifying the original tank and seperating it from the plenum. But I'll most likely go with a prefab kit.
Salt Lake City, UT
09 Teryx FI Sport
Rear cage Extension with top and seat
Muzzy duals
Dalton Clutch
HIDs
2010 Dodge 2500 Cummins
08 Weekend Warroir 3200FS
08 KFX 450R (mild mods)
06 Ltr-450 (heavy mods)
99 Yamaha Badger 80
DamnBigPapa is offline
post #2 of 20 (permalink) Old 10-18-2010, 09:02 AM
John@UTVCRAP's Avatar
on the big bore kit you have to drill the cyl ... and it will flow more oil then the reg kit .. most guys with big bore are running higher rpm
UTVinc.com is Located at 4244 West Dunlap Avenue Phoenix Arizona 85051
Email [email protected]
Phone 623-934-3070
Please understand we support many forums and cant keep up with Private messages or questions on the forum boards so If you have a question Please Call the Retail Shop 623-934-3070
post #3 of 20 (permalink) Old 10-18-2010, 11:42 AM Thread Starter
SO you feel that my stock bore, with MSD, Clutch, and Muzzy Exhaust ... the standard bore kit would suffice? It's puked back into the intake 3 times now. 2 Times at 60+mph and once on a long hill climb at St Anthony.
Salt Lake City, UT
09 Teryx FI Sport
Muzzy duals
Dalton Clutch
HIDs
99 Yamaha Badger 80
post #4 of 20 (permalink) Old 10-18-2010, 03:20 PM Thread Starter
As I stared at the stock mechanism last night ... I found myself questioning why not to just modify the OE catch can (2009) to an outside vent and block the vent into the plenum. I don't think this was an option on the 08, but I'm not sure. I just keep coming back to the fact the there's already a resevoir there, it just get's siphoned into the plenum due to the vaccuum I'm sure.
Salt Lake City, UT
09 Teryx FI Sport
Muzzy duals
Dalton Clutch
HIDs
99 Yamaha Badger 80
post #5 of 20 (permalink) Old 10-18-2010, 07:38 PM
sconym's Avatar
check with sandjunkie...he has a kit that looks very nice
08 LE, DASA 840, Muzzys, CDI, Open Filter Carb setup, VFJ Stage 3, XMF LT w / WER shocks, XMF 2 seat radius cage, XMF bed delete kit and bumpers, Lowrance Baja 540c GPS, HID's, 14" MSA MCX tires on black MSA Diesels, Twisted Stitch Agressors w / XMF seat bases, and a whole bunch of other shit!
sconym is offline
post #6 of 20 (permalink) Old 10-18-2010, 08:08 PM Thread Starter
My bud and I just made one using the existing resevoir. We blocked off the inlet in the plenum, as well as the outlet from the resevoir going into the plenum. Just some plastic we had around cut to fit. Sealed those up and moved on.
I threaded in a hose fitting barbed for 3/8" rubber hose into the upper most rear portion of the resevoir (Angled toward the rear). Ran about 18" of rubber hose back the the top/rear of the airbox, making sure we didn't have any big dips in the hose. Then capped that off with a oil element (K&N type) filter.
Pretty slick and it looks good using the original resevoir. Took it out and ran the crap out of it, including a pretty long run rapped out ... no burp.
I'll post some pics later. Just had to make sure it worked before I posted any of that.
Salt Lake City, UT
09 Teryx FI Sport
Muzzy duals
Dalton Clutch
HIDs
99 Yamaha Badger 80
post #7 of 20 (permalink) Old 10-18-2010, 09:45 PM
Why yes I do...
post #8 of 20 (permalink) Old 10-19-2010, 06:30 AM Thread Starter
Originally Posted by SandJunkie View Post
Why yes I do...
So Sandjunkie ... do you see any inherent problems with what I fabbed up? I realize that if I had an 840 ... my setup might not be enough.
Salt Lake City, UT
09 Teryx FI Sport
Muzzy duals
Dalton Clutch
HIDs
99 Yamaha Badger 80
post #9 of 20 (permalink) Old 10-19-2010, 02:05 PM
If you dont vent somewhere else the oil still pushes into that line, you just made it longer in hopes it doesn't reach the filter you put on the end.
i had the UTV Crap one installed on my 09 it did what it was suppose to, keep oil out of the plenum. however it filled up and spit out of the filter.
i now have the threaded tappet (valve) covers and also a billet threaded nipple in the timing peep hole. all of those hoses now run to a breather catch can that is up higher mounted to my bed.
the whole point is to relieve the crank case preasure with out loosing the oil.
UNLEASHED has the billet timing peep whole inserts
fitzazpb is offline
post #10 of 20 (permalink) Old 10-19-2010, 08:42 PM
Should be ok I think...tough to say...the real tests seem to be incline pulls...long hills like Oldsmobile where you are on the rev limiter...or dyno pulls...
But hey if it works then why fix it?...
But if not then PM me and we can hook you up with one of our kits...
DIY Siphon Break az_amsoil Kawasaki Teryx Performance Discussions 9 09-21-2010 05:54 PM
YFZ Siphon Break Questions JAKE JANACEK Kawasaki Teryx Performance Discussions 23 08-07-2010 06:40 AM
YFZ Siphon Break Problem SandJunkie Kawasaki Teryx Performance Discussions 20 05-06-2010 09:15 AM
siphon break??? powertrippin Kawasaki Teryx General Discussions 13 08-18-2009 10:12 AM
Siphon break? SRX Kawasaki Teryx General Discussions 6 05-10-2009 04:08 PM
