2010 msd - Kawasaki Teryx Forums: Kawasaki UTV Teryx Forum
post #1 of 13 (permalink) Old 04-13-2011, 01:24 PM Thread Starter
HappyGA's Avatar
2010 msd
I am not new to programmers or plug in boxes, but i am new to them when they are installed on an ATV. I have always had them on my diesel trucks.
My questions are...
When putting something like an MSD on your teryx, do you need to have the teryx modded in any other way?
Will adding the MSD increase the likelyhood of breaking the engine?
The power that is added, does it re-write the fuel mapping, or is all the power gained based on the eliminating the top end limiter?
HappyGA is offline
post #2 of 13 (permalink) Old 04-13-2011, 06:20 PM
SouthCo's Avatar
On a stock machine with just a MSD, your gaining more top speed by raising the rpm limiter and I think most advance the timing some for some additional power.
2010 Teryx
SouthCo is offline
post #3 of 13 (permalink) Old 04-13-2011, 06:25 PM
The Charge FI modifies the stock fuel flow rate, and timing advance which is fully user adjustable via the "spreadsheet" style software it comes with. You can add or take away fuel based on throttle position and rpm. The timing is also added to the factory advance, it is based on map and rpm.
As far as modifications, you will most likely get oil pushed in the intake if you raise the rev limiter past 8600 or so. IMO the Msd a good choice for noticable power gains.
I also recall reading somewhere that the teryx timing is retarded 12 def until you reach 10 mph.
krazykoser is offline
post #4 of 13 (permalink) Old 04-14-2011, 05:41 AM Thread Starter
HappyGA's Avatar
Good info. So, is the MSD an adjustable type box? Or does it come pre-programmed with settings in it and then just plug and play?
The reason i ask if it is adjustable, for now I am going to leave most everything stock, and then as time goes on and learn more about my machine and get a plan on what I want it to be able to do, i will then start making mods, but for now it is just something me amd my wife can enjoy riding dirt roads.
HappyGA is offline
post #5 of 13 (permalink) Old 04-14-2011, 05:43 AM
MSD did not address a timing retard and I can't find proof the EFI version of Teryx has a timing retard. Watching the timing advance function live on the MSD the timing advances as soon as you start revving the engine up.
post #6 of 13 (permalink) Old 04-14-2011, 05:46 AM
My questions are...
No need in adding anything else when adding the MSD but don't expect alot by itself except to get by your rev and speed limiters. Very little gains can be had by playing with timing and fuel on a otherwise stock Teryx
Adding the MSD has no bearing on the reliability of the engine
Question three was answered in answer one.
For a real power gain, add the Muzzy pipe along with the MSD. We preprogram the MSD to match the pipe.
post #7 of 13 (permalink) Old 04-14-2011, 05:50 AM
The Msd comes pre- programmed, and is also adjustable. There is 10 setting on it. The first 3 come pre-programmed from Msd, the other 7 are fully customizable. Depending on where you choose to buy from, it might come with more tunes programmed. I would recommend you check out Hunterworks, he has done alot of testing and has good maps for stock exhaust, also a good price and very helpful.
post #8 of 13 (permalink) Old 04-14-2011, 06:54 AM
As it comes from MSD it is not actually pre-programmed it has ten programmable curves and several are locked out but companies like Hunterworks take a vehicle add mods and then make maps to match actual products.
post #9 of 13 (permalink) Old 04-14-2011, 07:36 AM
Buy from a vendor that gives you the programmed msd.
post #10 of 13 (permalink) Old 04-14-2011, 10:16 PM
If you don't know better and set the rev limiter to high it could definately have a drastic effect on the reliability of the engine.
2010 sport blw2277 Kawasaki Teryx's & Teryx Parts For Sale 2 10-20-2010 06:37 AM
Got my 2010 Teryx lonestar8839 Kawasaki Teryx General Discussions 22 03-16-2010 05:43 PM
2010 Wendover 300 Deviant_Illusion UTV Desert Racing 2 03-05-2010 07:15 AM
2010 King of the Hammers UTV Race - Feb 11, 2010 Crowdog UTV Desert Racing 0 12-17-2009 11:16 AM
