2008 Teryx wont start - Kawasaki Teryx Forums: Kawasaki UTV Teryx Forum
Member Introductions We are happy to have you with us, please take a moment to introduce yourself to the rest of the members.
post #1 of 4 (permalink) Old 10-11-2010, 05:21 PM Thread Starter
I was riding this weekend and by the end of the trip it would not want to idle. I figured that the filter was plugged since it was dusty and would wash it to fix the problem. Before i unloaded it out of the trailer I washed the filter. Went to stat and nothing. Just turn over with no fire. Installed new plugs both have spark with you hit the key. Drained both cards, Pulled the gas line off by the carb and when i cranked it gas flows. Checked oil level, coolant all is good. What am I missing. Charged the battery last night and this morning same thing.
wis4wheeler is offline
post #2 of 4 (permalink) Old 10-11-2010, 07:38 PM
nyteryx's Avatar
How many hours does it have on it? it may need a valve adjustment. I found that if you turn the idle up quite a bit it may start or give it some gas as you crank. If these make it run you may have to adjust your valves, as you have check the first few obvious things. At least thats what i found out when mine would just crank and not start till I applied throttle or turn up the idle. Good luck and hope this helps. Im shure more people will chime in with ideas.
nyteryx is offline
post #3 of 4 (permalink) Old 10-11-2010, 09:16 PM
Is it not normal to have to give it a little gas for it to start? I have 35 hrs on mine and ive always had to give it a little pedal for it to start. just turning the key wont do it unless it is hot.
Tearinitup is offline
post #4 of 4 (permalink) Old 10-11-2010, 09:55 PM
It is also possible that you'r air cleaner was dirty, when you cleaned it did you oil it, and if so is it the same oil you always use, I changed oil once and it was to thick my uni twin air could not breathe and I had a bad idle and no throttle response , worth cleaning again for possible easy fix.
shady is offline
FST pedal wont idle monstertrex Kawasaki Teryx Performance Discussions 5 05-28-2010 07:11 PM
09 Teryx Sport won't start !!!!! mrcr5 Kawasaki Teryx General Discussions 1 05-09-2010 05:27 PM
2008 teryx le mark5193 Kawasaki Teryx's & Teryx Parts For Sale 0 12-07-2009 05:26 PM
750 Teryx 2008 grizz663 Kawasaki Teryx General Discussions 10 08-02-2009 09:43 AM
Teryx wont start bduncan1231 Kawasaki Teryx Performance Discussions 12 01-31-2009 05:46 PM
