2010 Radiator Upgrade Thoughts - Kawasaki Teryx Forums: Kawasaki UTV Teryx Forum
Unleashed UTV Unleased UTV
www.unleashedutv.com
602-246-4011
post #1 of 18 (permalink) Old 01-28-2010, 05:02 PM Thread Starter
Unleashed UTV's Avatar
So I ordered everything from Kawasaki for the upgrade to see what the differences are. I get 15% above cost (supposidly) and the complete kit with hoses pipes thermostat housing radiator and radiator fan was $535.00 and some change. So Muzzy's price they have posted is a good one. However I am not so sure all this money is absolutely nessesary to spend now that I have it all in my hands. The radiators are the same size with the same number of rows in the core. There are 2 differences, the size of the hose spickets and there is no bung to screw the temp sensor in the 2010 radiator. There is a slight difference in the tubes in the core they flare out more where they come through the header to the tank but I am not sure that gets more effenciency. The key thing to me is Kawasaki does not change the water pump cover or the size of the spicket going into the water pump cover, so the larger hoses run into a restriction at the water pump housing. The biggest difference I see is the fan itself. It is almost double the size of the 2008 fan covering the whole core of the radiator. The 2008 fan is much smaller and the schroud is close which causes a back up of air flowing through the complete core of the radiator. I have not tested yet, but I believe the the fan alone along with a good water pump upgrade would make the difference to keep big bore motors running cool.My 820 motor doesn't overheat with the waterpump upgrade but does still run up into the 215 range on long wide open runs. Here are some pictures to study. I will try to get some testing done with in the next couple of weeks to see if I can back up my thoughts here.
The 2 radiators in comparison
The fan difference
2010
2008
Sorry forgot the schroud on the 08 but you get the idea
The hose spicket size difference
2010
2008
These pics are a little blurry but this is the difference in the tubes where they come through the header.
2010
2008
I will try to get some better close up pics of the tubes in the core tomorrow.
Unleashed UTV
5838 N. 19th Ave
Phoenix, AZ 85015
Unleashed UTV is offline
post #2 of 18 (permalink) Old 01-28-2010, 06:55 PM
mark5193's Avatar
sounds to me like a 10" slim fan from the local auto parts store, and a dasa impeller would do the trick?
mark5193 is offline
post #3 of 18 (permalink) Old 01-28-2010, 07:20 PM Thread Starter
Yes if you mount is correctly for proper flow. I would the Unleashed UTV impeller kit though. lol!
Unleashed UTV
5838 N. 19th Ave
Phoenix, AZ 85015
post #4 of 18 (permalink) Old 01-28-2010, 07:45 PM
mark5193's Avatar
sorry, should have said (aftermarket billet) impeller, not dasa impeller.
mark5193 is offline
post #5 of 18 (permalink) Old 01-28-2010, 08:06 PM
Hillbilly's Avatar
How much is just the fan from Kawi and is it a plug-n-play that you could use on an 08?
Hillbilly is offline
post #6 of 18 (permalink) Old 01-28-2010, 08:14 PM Thread Starter
I need to look at my invoice but think around $150.00 and it has the same plug on it.
Unleashed UTV
5838 N. 19th Ave
Phoenix, AZ 85015
post #7 of 18 (permalink) Old 01-28-2010, 08:16 PM
mark5193's Avatar
you could buy an aftermarket one, cut the plug off your 08 version, attach it to your new fan and save $80, probably work better too!
mark5193 is offline
post #8 of 18 (permalink) Old 01-28-2010, 08:24 PM
Hillbilly's Avatar
Thanks, I looked at your pics a little closer and it looks like the new fan mounts a little different. Guess it could be made to work. Thanks again.
post #9 of 18 (permalink) Old 01-28-2010, 09:59 PM
Thanks for checking it out and posting pictures of the difference.
post #10 of 18 (permalink) Old 01-29-2010, 06:57 AM
+1
That would be great!!
2010 King of the Hammers UTV Race - Feb 11, 2010 Crowdog UTV Desert Racing 0 12-17-2009 11:16 AM
Quieting the teryx. Results, thoughts grizzjeeper Kawasaki Teryx General Discussions 6 10-15-2009 07:32 PM
Looking to Upgrade Blue Tick Kawasaki Teryx General Discussions 4 04-16-2009 12:57 PM
A Few Thoughts dieselpowered Humor & Jokes 1 08-06-2008 04:20 PM
Tire and Rim Options(Would like your thoughts) hitman2565 Kawasaki Teryx General Discussions 1 05-18-2008 05:41 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71
