1 - 1 of 1 Posts
Looking for any help possible.
2008 Teryx LE 1500 miles and about 110 hours.
Got a major engine knock that seems to be coming from the bottom end. Drained the oil, but did not look too bad. Double checked the valve tolerances, seem ok. Now engine will no long start, but does turn over/rotate fine.
I believe the crank and rod(s) let go, but not totally sure. Any thoughts would be appreciated.
Also any good local mechanics to the Covina, CA area would be great.
I know this is a major job, but I can easily remove the engine, but would want someone else to diagnose and rebuild as needed. Just wanting to keep it stock.
1 - 1 of 1 Posts
