Hey guys, working on an 08 Teryx and need to put on a back up alarm... so I am looking for a reverse ONLY lead to trigger the relay. Thus far I have tried to pull from under the dash but the leads I found went hot in both R and Lo or Hi..... I have also heard of the leads at the rear for reverse lights, but again, I found that those leads were hot in Rev or Lo or Hi.... Having a Hard time finding a reverse only signal....
HELP PLEASE :confused:
On the right rear corner by the tail light and the bed pivot on the fram is a small bundle of wires that are grouped up.
Take off the protective boot and you will find the reverse light trigger.
I believe it is a ground trigger. Not sure of the exact color, but make sure you use a relay, as it will burn out the reverse switch on the transmission because it is not heavy enough to run a very big load.
