My 08 teryx has 600 hrs on it. It started running rough when I tried to crank it one day. It died, I checked it out an the engine oil was full of gas. The heads also. I rebuilt the carbs, changed the oil and it ran good for 2 rides then did it again.
This happen after pulling it down the road on a trailer or just sitting in the garage?
If from just sitting and you've already cleaned the carbs you might want to pull the tank and flush it because you're having dirt come from the tank to the carbs and holding a needle open which allowing fuel to run in and if the check valve on the bottom of the carbs isn't flowing will run back into the engine.
If its doing it after pulling it some where do you have snorkels?
$ 850. Later I now have a new fuel pump. The rebuilt carb didn't work. Honda shop said my fuel pump was tilted and cracked. I don't know but I thought that was high.
