1 - 11 of 11 Posts
I have a 09 with tracks, I have the dalton clutch kit. Hear is my problem, after running a few miles it start loosing power, when you tromp on the go pedel it bogs down. I thought maybe my clutches were getting hot that is why I put on the dalton kit. Still have the same problem. Couple more things I learned today if i put my hand to block airflow into the airbox, basicly cutting the airflow in 1/2 I can get back some of my power with less bog. 1 more thing learned today if I stop and turn off the engine and restart bog is completly gone for a small distance but eventually starts loosing topend. I am thinking it has to be a sensor sending a signal to the ecu telling it to go into a rich mode. No lites are on and does not seem hot
Hunterworks, it seems like i saw either on your site or one of these fourms that if you get some kind of box you can plug your laptop in and read quite a few of the sensors, would this be a good starting point? Years ago I had a snowmobile that the temp sensor went bad and it would make the machine run rich, but since when i cut off some of the air it runs better this machine must be going lean which makes no sence at all.
ok, just ordered a service manual. Sure hope I can get this figured out as it is no fun to ride a slug.
Same here started doing it 5 days ago.MSD with dasa program Dalton clutch n muzzy exhaust did 70 mph.At first top speed was 54 mph went on a 100 mile cruise at the end could barely go 15 mph. tps is showing 100% at WOT .coolant sensor is working fine.Im thinking fuel pump or factory ecm..?Dont want to just guess at it .come on help me out!
mine turned out to be a bad fuel pump and after owning for almost a year and over 3k Kawasaki warntied the pump...But now I have a problem where the speedo starts reading lower then the actual speed and then the belt lite come on then it goes to limp mode....
yeah.Thanks for the update! thinking it was the pump.Im over a year but will ask the dealer.over 400 for a pump.did you take it in to the dealer for your new problems?Are you running a programmer on ur teryx now? starting to think i need to buy a spare one for parts or sell it ! Thanks again for the info
No programer on the machine, have not taken to the dealer yet for new problem...I am starting to think that new can am looks pretty nice
1 - 11 of 11 Posts
