Changed out a bearing on the crankshaft and put motor back together
now it is backfiring on rear cylinder. Have changed injectors around to see
if I had a bad injector but was not the problem front cylinder is running good
and back cylinder is the one that is backfiring. Has anyone ever had this problem. Had someone check the timing and they said that the timing was right.
Any suggestions would be greatly appreciated.
Checked the timing? Explain how it was done cause it sounds like the piston to cam timing is off. Very easy to get one of them off
