I have a 09 teryx Sport with 23hrs on it and it won't start. I cannot hear the fuel pump running, I think that it is not getting any fuel. I checked the fuse for the fuel pump and it was good. Is there any other relays or something that i should check that anyone knows about?
your fuelpump shuts off after it builds pressure,so pull your fuel line off at trrottle bodies, its just a quick connector, and then turn key on,make sure fuel line is pointed away from tou though it will shoot a good ways.as far as relay there should be one over on relay rail under seat, not sure witch one though,just be sure if your doing electrical troubleshooting to pull fuel line off, if its holding pressure you wont get any action at relay
