Hi All! Need some help with a 2010 Teryx.
I'm coming off a Rhino, so I'm getting use to the Teryx. Is it normal for the clutch to grab in 2WD/High as soon as you let off the gas?
Even on a flat surface, it feels as if you've kicked it into low, even get some belt squeal once you stop/idle. I have added Bighorns, but kept them at 26" to not over-stress the axles or the clutch.
I've heard there may be some issues with the clutch on the 2010, but can't find anything definitive.
Any thoughts?
